NOS ? - Page 2 - Smart Car of America Forums : Smart Car Forum
Trailer
Closed Thread
Old 07-11-2008, 10:31 PM   #11 (permalink)
SmartPassion's Avatar
That should get the groceries home quick.
SmartPassion is offline
Old 07-15-2008, 04:58 PM   #12 (permalink)
Nitrous would be a Smart fit
Nitrous would be the best of both worlds, great unaltered gas mileage with Brabus performance. A conservative 40% wet shot (30 HP increase) just when you need it. At 40% no need for backing off timing, colder sparkplugs or expensive performance upgrades. The only item that I see that has to be worked out is using a bottle smaller than 10 lbs that you can still find a heater to maintain 90 deg. pressures at without having enough nitrous to last 5 plus minutes at. How many years would it take to use 5 plus minutes "ON". All of this for less than an exhaust that everyone raves about?? To each his own.
jsego is offline
Old 07-15-2008, 05:52 PM   #13 (permalink)
NOS? In a Smart? That's HILARIOUS!!!!!
PlainCityVWBug is offline
Old 07-20-2008, 07:08 PM   #14 (permalink)
I doubt there's any kit made for the Smart yet. But there's a few universal kits that you can put on any car.
One is called "Nitrous in a Bag" by Nitrous Works ($400?). Comes with 10 lb bottle, a duffel bag, 20-100 hp jets, etc. Everything you need. You feed a nitrous line from the cockpit to the front of the mass air meter. You plug the power cord into your cigarette lighter. It's sprays right in front of the mass air meter and tricks the computer to go into cold start mode where it will adjust air/fuel mixture to be on the very rich side.
The dangerous part is that nitrous is activated by a button that you press and hold. So you have to make sure that you press this button ONLY when you're at WOT....wide open throttle....your gas pedal pressed all the way to the floor....where you're getting lots of fuel delivery....otherwise you're spraying nitrous w/o enough fuel and it can blow your motor. I would start with 20hp and probably not go over 40hp. It's a dry shot, so 20hp would give you about 15 hp.
The kit is easily removed and put on different cars. Just that it doesn't have any safety measures. Hard for dealers to know, but there is a small hole you must drill near the mass air meter to feed the nitrous line through.
Another kit is called "Sneaky Pete" made by NOS.
I would definitely change the spark plugs to 1 or 2 heat range colder. Never use platinum plugs. Use the regular copper ones. And 93 octane gas. Maybe put in a bottle of octane booster to be on the safe side. 1 bottle = about +1 octane boost. Then check the plugs right after one NOS run to see if there's any detonation.
hissingsnake is offline
Old 06-27-2010, 09:54 PM   #15 (permalink)
CT Chapter President
smartcar111's Avatar
So I am going to attempt to revive this thread.
I was going to start another thread, but since this thread had the title that I was going to use, I want to ask this question:
Does anybody yet have NOS in their smart car? If you do, what kit did you use and what shot did you use?
smartcar111 is offline
Old 06-28-2010, 06:26 AM   #16 (permalink)
I believe turbo 42 has a bottle in his car
forestacademy is offline
Old 06-28-2010, 11:19 AM   #17 (permalink)
He has a turbo and NOS in his car and it still runs like a lame cat with three legs! LMFAO
IH8OPEC is offline
Old 06-28-2010, 11:26 AM   #18 (permalink)
I wasn't going to say it
Old 06-28-2010, 11:40 AM   #19 (permalink)
Ih8opec, do you have nos? Your icon seems like you would unless you just like the icon.
Old 06-28-2010, 12:10 PM   #20 (permalink)
I have a progressive 125hp wet fogger kit on my 85 Fiero GT, but not my smart. No company makes a kit that can be used with the smarts fly by wire system ATM.
I've contacted NOS systems in Bowling Green KY about developing a kit for the smart but haven't heard anything back yet. BTW if we get more people to call Mr. Jay MacFarland at NOS systems they may be inclined to speed up the development process!
270-781-9741 between 8 am and 6 pm CST Monday - Friday, and between 9 am and 3pm CST on Saturday.
IH8OPEC is offline
Closed Thread
