The purpose for me is to hold the motor from moving so much,
I have a Volvo that I had to change the motor mounts on after 50,000mi because they tore under normal use. I upgraded them to Urethane and it has held up for over 140,000 now.
I have played with VW bugs, (rear engine, Transaxle, kinda similar in that respect) and by upgrading to stiffer mounts the car leaves smoother from the line. If the Engine/Transaxle shakes when it is engaging or shifting then it will jerk. especially when trying to be smooth and slow. I noticed that the engine moves around quite a bit, with the engine cover off, grab the alternator and push the motor from side to side.
Again, I don't question someone adding a side pouch to the shifter, I don't really want it, I think that they found a good solution for making one fit.
I appreciate your reminder about the posts, I am going to work this anyway and figure it out. then I will mess around with other stuff too.
