Question RE: secondary air injection pump - Smart Car Forums
post #1 of 19 (permalink) Old 06-07-2011, 07:49 AM Thread Starter
gurps's Avatar
Before I claim victory, can anyone physicaly confirm that the secondary air pump - that turbine sounding thing- will come on when the coolant is at around 70 degrees F? The documentation says between 7 and 36 degree C, but the manual isn't always right.
Thanks
gurps is offline
post #2 of 19 (permalink) Old 06-07-2011, 07:58 AM
Quoted: 68 Post(s)
How do we know what the coolant temp is? smart very cleverly left out our temp gauge. Are you looking for the max temp at which the pump comes on?
jwight is online now
post #3 of 19 (permalink) Old 06-07-2011, 08:04 AM
BB Benz's Avatar
Quoted: 226 Post(s)
Scangauge shows coolant temp.
BB Benz is offline
post #4 of 19 (permalink) Old 06-07-2011, 08:05 AM Thread Starter
gurps's Avatar
I use an OBDII tool like scan guage, or others. Since I no longer have the pump I wanted to make sure that is SHOULD have turned on when the coolant temp was 70. Starting the car after it sat overnight would be good enough too....
gurps is offline
post #5 of 19 (permalink) Old 06-07-2011, 08:50 AM
BB Benz's Avatar
Quoted: 226 Post(s)
Sorry, Tom. You want specs! and we ALL know how elusive those things are! How is your little project coming along?
I notice that it does and does not turn on in the a.m. depending on temp but have not made note of actual temp. It is probably too warm to turn on today. I'll start making notes.
BB Benz is offline
post #6 of 19 (permalink) Old 06-07-2011, 08:55 AM
BB Benz's Avatar
Quoted: 226 Post(s)
It does come on at coolant temp of 84 degrees. I can tell you that.
BB Benz is offline
post #7 of 19 (permalink) Old 06-07-2011, 09:52 AM Thread Starter
gurps's Avatar
The 'little' project is progressing well, very well. This is a small diversion where I made a modification to eliminate that CEL for a missing air pump while I was doing some other stuff down there. Would like to double check that I really did find a way to stop that CEL
gurps is offline
post #8 of 19 (permalink) Old 06-07-2011, 10:22 AM
BARNEY O's Avatar
Quoted: 123 Post(s)
Was the code P0410 ?
BARNEY O is offline
post #9 of 19 (permalink) Old 06-07-2011, 10:30 AM Thread Starter
gurps's Avatar
I don't remember. It hasn't come back since my mod. It was definitely the Secondary Air Injection system.
gurps is offline
post #10 of 19 (permalink) Old 06-08-2011, 04:45 AM
BB Benz's Avatar
Quoted: 226 Post(s)
Well, it was 76 degrees outside. Once the engine started, the scangauge's first coolant temp was 84. The air injection pump ran! That was checked about 6:15 this a.m. I didn't drive the BB yesterday at all so coolant temp is due to our record breaking 98 degrees here yesterday. As I listened to the air pump, I watched the coolant temp almost immediately go to 92 degrees. It warms rapidly.
BB Benz is offline
Human Verification
331
P0410 Check Engine Error Code, Secondary Air Injection System Fault paulmorr smart Operation and Maintenance 50 11-15-2016 07:37 PM
P0410 Secondary Air Injection System Malfunction NY Smartie smart Operation and Maintenance 94 04-01-2015 01:52 PM
Air conditioner pump from 2008 passion gocart2010 storage, obsolete threads (locked) 4 10-23-2010 06:14 PM
Smart Air Pump SmartJoeMN Archive/obsolete (?) threads 11 12-10-2009 05:41 PM
Secondary Air Valve Replaced kulak smart General Discussion 7 01-13-2009 10:37 AM
