Originally Posted by joey17
thanks alot larry and boris i understand now. so could we get a pic with the regular lights on and then the hid i just want a comparison you no. if its only that much money then i will be picking a set up as soon as i get my smart. thanks
joe
yea I can get you a picture of the beam output. It's just regular HELLA halogen projectors in our SMART headlights with THREE Times the light output! wOo Hoo! The advantage to Boris setup is that his packaging is as oem as possible, the HID components, the bulb, the light and output is all pretty much the same... except for some minor difference such as aftermarket HID ballast made in taiwan, china or anything hid aftermarket would offer a system that are like "digital" or what not or... a resistor attached to prevent the check engine light from turning on , on european vechiles with the CAN-BUS system. I always stick with factory OEM components with ballast made by philips, kyoto, hella, denso, masi****a (typo) etc.. but having those parts in a cusotm cap would require a huge investment probably 10x what Boris has invested in these
Just so our fellow smartie can make an informed purchase... anything higher then 4300k is less in light output even though it'll look bluer and purple. So start going above 5000k like.. 6000k and above and it'll get blue and purple and the actual light output on the ground will be less, even though it might "seem" brighter if your stnading in front of the car because our eyes are more sensetive to the color blue. I hope Boris will be able to offer 4300k or at least 5000k
that'll be a good combination.. great light output, and high quality factory like cosmetic apperance.
Cheers!
Larry
