shorter antenna - Smart Car of America Forums : Smart Car Forum
Trailer
Old 05-26-2008, 03:11 PM   #1 (permalink)
donnyonee's Avatar
shorter antenna
i just shortened my antenna about 1/2 because it looks cool and doesnt effect reception "too?" much. if your interested in doing so...
1. unscrew the antenna ccw out of mount.
2. score with a razor blade around the tip base on the shaft.
3. get a small pan of boiling water and put the tip into the boiling water for a 30 sec?, so you can pull the end off the shaft, "cough"
4. carefully cut the shaft with a hack saw as cleanly as possible. to the length you want.
5. gently twist the cap back onto the antenna in the direction of the wound wire.
6. if necessary put a drop of zap glue in the cap before installing.
7. stand back and look at your cool antenna and think how you just saved yourself a few bucks. it still receives about the same. i put a towell for a background in the pics so the antenna shows better.
Old 05-29-2008, 04:14 PM   #2 (permalink)
chrisdfw's Avatar
I prefer the J-series extendable stubby antenna off ebay. It pulls in most stations just fine at only 4 inches long and extends to 10 inches if I need to pull in a far away station. I use Ipod mostly so never need to extend it.
chrisdfw is offline   Reply With Quote
Old 05-29-2008, 05:00 PM   #3 (permalink)
curtis's Avatar
yeah for $10 you can get a stubby off ebay in black or silver with 3 different lengths, I have had one since I got my Smart and it works and looks great!
Help with Sirius Antenna Install Djinn Audio & Video 15 11-23-2008 06:14 AM
Stubby black pull out Antenna - j series chrisdfw Interior & Exterior 15 05-14-2008 09:59 AM
Stubby antenna for the fortwo SMART Interior & Exterior 22 03-09-2008 09:36 AM
