Soften suspension help - Smart Car of America Forums : Smart Car Forum
Old 12-18-2008, 06:50 AM   #1 (permalink)
I live in NE Ohio, lousy road HQ of the world. Any suggestions for softening the ride over potholes and bumps?
Thanks!
p926sc is offline   Reply With Quote
Old 12-18-2008, 07:29 AM   #2 (permalink)
SeCrEt AsIaN MaN
tigerwong58's Avatar
I think the only way to soften a ride is lower air pressure (26-29PSI), but then the TPC light will come on. The springs and shocks are already pretty soft, especially if you can rock the car with one hand. I would say, you may need to get used to it.
Old 12-18-2008, 07:51 AM   #3 (permalink)
Agent 99's Avatar
Thanks![/quote]
Swerve......alot.
Agent 99 is offline   Reply With Quote
Old 12-18-2008, 07:53 AM   #4 (permalink)
you can change the air pressure in the tire as said (not too low) and when you reset the TPMS the new pressure will be the referance pressure.
Old 12-18-2008, 07:57 AM   #5 (permalink)
Originally Posted by p926sc View Post
I live in NE Ohio, lousy road HQ of the world. Any suggestions ...?
Thanks!
Move?
Old 12-18-2008, 08:45 AM   #6 (permalink)
Has anyone measured the spring rate of the stockers? I haven't bottomed mine out yet but it does transmit a boom into the car when you work the suspension. To me the Bark is far worse than the bite. That is only my uncalibrated buttometer.
Old 12-19-2008, 01:40 PM   #7 (permalink)
lowndex's Avatar
Consider changing the tires and wheels
To 16 or 17" and widen the offset. I did and the stock ride was greatly improved. Of course, $1200 for wheels and $600 for new tires is a big proce to pay for a softer ride.
Old 12-19-2008, 01:49 PM   #8 (permalink)
Shorter, stiffer sidewall = softer ride.
Your tire and wheel salesman is underpaid.
Old 12-19-2008, 02:26 PM   #9 (permalink)
DavidV's Avatar
I can tell you what not to try - softer springs. You can compress the front springs by hand. They are ridiculously soft.
-- DavidV
DavidV is offline   Reply With Quote
Old 12-24-2008, 11:31 AM   #10 (permalink)
Git ya some taller tars ....
The wide and low profile tires don't provide very much cushion effect. The suspension is actually pretty soft on these little buggers ... JMHO
