Speed Force Racing Smart car turbo system - Smart Car of America Forums : Smart Car Forum
Old 09-07-2009, 01:46 PM   #1 (permalink)
Supporting Vendor
SpeedForceRacing's Avatar
I just wanted to get back on here and let you guys know we are still around and doing well. We just recenlty moved into a new 7500 sg/ft shop and sort of droped the ball on the boards here. But now that we have settled in, we are back to make a name for ourselves and get more of you Smart owners turbocharged.
As you all know, we were the first company to introduce an OEM like tubrocharger system for the Smart 451 back in March! Since then we have sold over 30 of these systems! Our test car has reached well over 10,000 miles and still running strong. Recently, we felt comfortable enough to get a little more aggressive with our tuning on the Smart stage 2 system and we picked up another 50 ft/lbs of torque and have seen gains as high as 30 WHP in the midrange over the initial stage 2 turbo system results! And this is at 9 psi of boost. What this means to you is.................the car actually feels like a fast car now.Initially the turbo system transmformed the car for sure.It felt much quicker then a stock car or even a car with the tyical bolt-ons like CAI,exhaust,etc.......But now the car feels fast! It pulls you into your seat fast!
And to all of our existing customers, this new tune is available as a free upgrade for you!
Here is one of our distributors cars running at 15 psi of boost! Check it out! Its a fast Smart car!
__________________
Turbo Tim
Turbocharger Systems for the Smart
http://www.speedforceracing.com
Got questions? 619-328-4012
SpeedForceRacing is offline   Reply With Quote
Old 09-07-2009, 02:21 PM   #2 (permalink)
For sale pm for details
Turbo42's Avatar
and you have to live with a check engine light
Old 09-07-2009, 03:48 PM   #3 (permalink)
actully he has headers on that car thats what throws the cel .. not the turbo
foyfarlow is offline   Reply With Quote
Old 09-07-2009, 09:53 PM   #4 (permalink)
geosynch's Avatar
Impressive...
...I recognize that particular stretch of road!
geosynch
Old 09-07-2009, 10:25 PM   #5 (permalink)
Turbo42's Avatar
I realize this if you want to run more boost u need the header. As I was saying the check engine light is on. I would have a problem with that
Old 09-08-2009, 12:04 AM   #6 (permalink)
Gearhead's Avatar
The SFR turbo system doesn't trigger the check engine light. There are users who have installed the SFR turbo with the Thorley header -- and that header throws a check engine light. You can rig a "sim" inbetween the downstream O2 sensor and the ECU which tricks the ECU and avoids light but the CEL has no effect on the performance of the car. Running a header is not necessary for increased boost levels. As long as your IAT's are in check -- you can run much higher boost to good effect. Larry, the SFR distributor up in San Francisco, has rigged an Air-Water intercooler and is seeing IAT's not much above ambient temps at any sane level of boost.
I believe the reason for installing the SFR turbo with a header is that it allows for a very quick install. If you get the rear suspension X beam out of the way (it's just 4 bolts), you can take off the entire stock exhaust as a unit and install the SFR turbo in it's place as a unit. This also allows for a quick swap back to the stock exhaust if needed.
The SFR turbo welds are works of art. Unlike a lot of other aftermarket welding that I've seen, the SFR welds are aircraft quality. The tubing welds look like they were properly done in a purge-tank from inspecting both the inside and the outside of the tubes. Some of the other aftermarket welding I've seen shows overheating and oxidation to the point that both the weld and the surrounding metals are fried to the point of embrittlement. The first rule of racing -- is that to finish first, first you must finish! The SFR turbo is definitely built to go the distance.
Gearhead is offline   Reply With Quote
Old 09-08-2009, 06:14 AM   #7 (permalink)
Periclaws's Avatar
"And to all of our existing customers, this new tune is available as a free upgrade for you!"
I thought the boost was always adjustable on this kit,what is the free upgrade consist of?
Old 09-08-2009, 08:28 AM   #8 (permalink)
Supporting Vendor
SmartMadness's Avatar
We have this set up on one of our smart cars (Rachels) and have installed the majority of the kits that have been manufactured by SFR.
Their quality has been top notch and the units have held up very, very well. If you have any questions on the set up please do not hesitate to give us call.
__________________
Old 09-08-2009, 10:16 AM   #9 (permalink)
Supporting Vendor
Hey Boris,
Have you uploaded that new tune in your car yet???? Let me know if you need any assistance and thanks for your great support!!!!
__________________
Turbo Tim
Old 09-08-2009, 10:29 AM   #10 (permalink)
HerrZ's Avatar
Does the top speed remains 90 mph, and the trans still take a long time to shift? I realize the trans shicting is a design issue, how about clutch longevity? do you have any 0-60 numbers?
HerrZ is offline   Reply With Quote
Speed Force Racing Smart car turbo system SpeedForceRacing Performance & Handling 9 12-19-2009 03:07 PM
Smart Force Racing Turbo system released! SpeedForceRacing smart Modifications 129 04-30-2009 08:55 PM
To turbo or not to turbo that is the question. fpage77 smart Modifications 49 04-25-2009 07:21 AM
Racing Smart mahshadi San Diego smart Owners 5 07-13-2008 09:51 PM
smart racing at One Lap dcrooks smart General Discussion 1 05-06-2008 03:25 PM
