Speed Force Racing Smart car turbo system - Page 3 - Smart Car of America Forums : Smart Car Forum
Old 09-08-2009, 07:19 PM   #21 (permalink)
Originally Posted by HerrZ View Post
i didnt ask where the computer is.
No, but SmartJoeMN who's quoted in that reply asked about them.
Looks like a cool system, the only concern I'd have is how long it will hold up due to this engine being a fairly high compression ratio compared to fctory turbo engines, but I suspect that it'll actually be okay.
sandalscout is offline   Reply With Quote
Old 09-08-2009, 07:21 PM   #22 (permalink)
Originally Posted by geosynch View Post
OK, I confess I find myself getting more and more interested here. For me a turbo would come after a body kit, which has been on hold since early this year (the toy money has temporarily dried up). But, planning is half the fun. I have questions…
geosynch
1. Turbo is usually much quieter than a comparable naturally aspirated car making more hp....in fact given the choice you can usaully fly under the radar with a boosted car with a large exhaust vs the same exhaust without the turbo.....the turbo itself muffles ALOT of noise and the Dodge SRT-4 actually doesn't have a muffler because it has a turbo...true story lol
2. As you become more involved with cars you will probably learn enough to start taking the system off yourself and probably put it all back in by yourself....but its a pain...I feel you
3. Nitrous vs Turbo....if your a speed junkie and you want to feel the burst of power often the turbo will be much cheaper over the years.....if you only use the burst at the strip....nitrous is cheaper but limited...turbos build power smoothly whereas nitrous is a bit more of a shock. In small amounts nitrous is super safe...but it has its pitfalls....bottle refills, pressure drops, running purge lines, finding the right direct port system or limiting it to a small dry shot etc...
Given how stout these little engine seem to be the turbo route seems like a no brainer....
Bottle refills vary by area but you can spend a couple hundred a month in refills if you get silly....or maybe only $50-70 a month for one bottle a month...but say its $100 ---- in three years youll have almost spent what a turbo kit costs and the turbo kit would still be fine for quite a while longer and its ALL THE TIME.
So while nitrous certainly has its place...for street cars looking for more all around performance turbos make a lot of sense.
You can enjoy all your power all the time....not just in spurts
SergMadness is offline   Reply With Quote
Old 09-08-2009, 07:27 PM   #23 (permalink)
Supporting Vendor
SpeedForceRacing's Avatar
thanks!.. of course.. the cost for a turnkey system?
The stage 1 kit retails for $3499 and the install time is about 8 hours.The stage 2 system retails for $3999 and the install is about 10 hours. So.......... depending on how much you pay for labor, you would be into it for anywhere from $4 to $5K! But the boost in performance is well.................simple incredible!
__________________
Turbo Tim
Turbocharger Systems for the Smart
http://www.speedforceracing.com
Got questions? 619-328-4012
SpeedForceRacing is offline   Reply With Quote
Old 09-08-2009, 07:31 PM   #24 (permalink)
Supporting Vendor
The best thing I can say is that time will tell the story. But I can say this much, a couple cars have seen 23psi of boost and havent skipped a beat.The car in the video is runnng 15+psi on pump gas and stock engine for quite sometime with no issues! We have 10k miles on our test car with no issues. And the car is constantly boosted running between 9-10 psi.Actually, it is hard not to boost this car with the turbo on it because the power is very usable, especially in a car that is way underpowered to begin with! LOL
__________________
Turbo Tim
Old 09-08-2009, 09:35 PM   #25 (permalink)
Gearhead's Avatar
A swap-out of the turbo system for the stock exhaust would be quick. As I had commented elsewhere, the performance fuel injectors and piggyback ECU can probably be left in place for smogging as they would have no effect without boost and you couldn't tell anything from a visual inspection. As for smogging every two years, if you have an '09 Smart in CA -- you won't need to worry about this until 2014/2015. For many people, they probably would have moved on to a newer car by then!
Gearhead is offline   Reply With Quote
Old 09-08-2009, 09:47 PM   #26 (permalink)
Mike T's Avatar
..the only concern I'd have is how long it will hold up due to this engine being a fairly high compression ratio compared to factory turbo engines, but I suspect that it'll actually be okay.
Well in the case of the European smart 451 naturally aspirated engine, the CR is over 11:1. In the European 84 and 98 HP Turbo applications, the CR is reduced to 10:1, which happens to be exactly what the stock USA/CDN 451 comes with.
Mike T is offline   Reply With Quote
Old 09-08-2009, 10:33 PM   #27 (permalink)
Thanks for that, didn't realize the CR was the same for the turbo versions. I assume that the CR was reduced in the US versions due to less strict fuel requirements in the US versus Asia and Europe. I know that's fairly common practice. Most US model Mitsubishi turbo engines that I'm familiar with are in the 7.8-9.0 CR range.
Does the 3B2 have oil squirters?
Old 09-09-2009, 12:57 AM   #28 (permalink)
geosynch's Avatar
Thanks for your response. I used to enjoy working on my cars, motorcycles and bicycles. But as I've gotten older and grumpier, money became easier to come by than time.
Turbo lust will linger for a while. I'll probably give in some time in the next 12 or so months.
Best,
geosynch
Old 09-09-2009, 05:20 AM   #29 (permalink)
Periclaws's Avatar
New tune with slightly more aggressive maps (with huge payoff lol)
A little ignition advance goes a long way
So how would this be delivered to the customer,do you flash the piggyback computer?
Old 09-09-2009, 11:48 AM   #30 (permalink)
Nice setup! any dyno charts ?
erkinak is offline   Reply With Quote
Speed Force Racing Smart car turbo system SpeedForceRacing Performance & Handling 9 12-19-2009 03:07 PM
Smart Force Racing Turbo system released! SpeedForceRacing smart Modifications 129 04-30-2009 08:55 PM
To turbo or not to turbo that is the question. fpage77 smart Modifications 49 04-25-2009 07:21 AM
Racing Smart mahshadi San Diego smart Owners 5 07-13-2008 09:51 PM
smart racing at One Lap dcrooks smart General Discussion 1 05-06-2008 03:25 PM
