tachometer options - Smart Car of America Forums : Smart Car Forum
Old 06-01-2009, 11:19 PM   #1 (permalink)
tachometer options
auto meter was totally clueless although i read a member on here figured it out with their parts but that doesn't say to much about their tech people so i went off to see if there is a tach for a 3 cyl and found these
Sunpro®
EQUUS PRODUCTS, INC.
Gray 7 Color Tachometer Gauge
Tachometers from Speco Thomas
rexxxlo is offline   Reply With Quote
Old 06-02-2009, 07:04 AM   #2 (permalink)
Sunpro®
After paying for "parts" AND the tach, you'd be spending more than the $120 it costs when you do your configuration from the factory........
Old 06-02-2009, 07:35 AM   #3 (permalink)
Well for pure ownerd and passion owners that don't have one(me) its definately the way to go and a few of these can be had for as little as $50 if you search a bit
Old 07-13-2009, 05:52 PM   #4 (permalink)
Did you put one in? Can you share your experience?
mirando is offline   Reply With Quote
Old 07-13-2009, 06:22 PM   #5 (permalink)
gryphon's Avatar
Try this:
Ecometer from Auto Meter: Features
The Auto Meter Model 9100 "ecometer" for smart 450 and 451 models, plugs into the OBDII port and is a 2 1/16 inch dia. gauge.
"Customizable to the specific vehicle’s type (compact, full size, crossover/mini-van or truck/SUV.)
Uses proprietary software to calculate fuel economy performance (real time and/or average.)
Display real time fuel economy performance in both a radial energy consumption graph and in a precise, easy-to-read digital format.
Offers 4 different modes that can be easily selected by the driver at the touch of a button.
Instantaneous Fuel Economy, Average Fuel Economy, Digital Tachometer with Instantaneous Fuel Economy, Digital Speedometer with Instantaneous Fuel Economy"
Uses both analog and digital presentation.
I have ordered one of these but it has not yet arrived and the cost to me was $82 including S&H. I have the factory tach and clock and primarily wanted an easily observable fuel economy gauge. Should have more info in a week or so after the unit arrives and will post here.
gryphon is offline   Reply With Quote
Old 07-13-2009, 09:27 PM   #6 (permalink)
kinda looking forward to it. Although seeing as it cost you $82, the Scangauge 2 kinda seems like the better option for another ~$70. not only gives you current fuel consumption, but also engine temps, average fuel consumption, reads error codes, and all kinds of other stuff.
and rexxxlo, i believe what he was saying was it's probably more worthwhile to have the factory tach and clock installed (or just the tach, if that's possible) than to buy an aftermarket one that's more than likely require drilling into the dash or something. Not to mention it would match the styling of the Smart perfectly, and not make it look like you're trying to turn it into a street racer or something.
ElementalDragon is offline   Reply With Quote
Old 07-13-2009, 10:18 PM   #7 (permalink)
Model Years
451 (Diesel) 2008, 2009
451 (Gas) 2007, 2008, 2009
ForFour (Diesel) 2006 , 2007,2008,2009
From their website; don't think the ForFour info is correct.
Originally Posted by gryphon View Post
Try this:
Old 07-13-2009, 11:22 PM   #8 (permalink)
24-42's Avatar
[QUOTE=gryphon;248744]Try this:
Sorry to say. the site for the ecometer does not mention the "450" or the "fortwo".
I wish it were otherwise.
Donald LaFavor
24-42 is online now   Reply With Quote
Old 07-14-2009, 12:05 AM   #9 (permalink)
...... well... you're correct that it doesn't mention the "450".... but i don't know what you mean by not mentioning the "fortwo". The Smart ForTwo we have here in the US is the Gas 451.
Old 07-20-2009, 01:26 PM   #10 (permalink)
gryphon's Avatar
"Received the ecometer and did...". I am aware that the pictures are not displaying properly. Don't know why at the moment but will attempt to correct the problem.
Tachometer lowndex smart General Discussion 38 10-18-2009 06:52 PM
Tachometer Pod Options? smcnally smart General Discussion 3 05-27-2009 04:00 PM
Tachometer Programming? briansmart Modifications and Repairs 6 11-17-2008 09:41 AM
Tachometer kgeissler smart General Discussion 4 08-15-2008 12:29 PM
You need Tachometer!!! thedefchef smart General Discussion 1 01-24-2008 09:13 PM
