Originally Posted by foyfarlow
hey i was wondering did you just clear the lower valances or did you use black?
What I did was sand off the texture with 220 grit dry paper.
Next I primed the parts with a plastic adhesion promoting primer.
I then put three coats of epoxy primer over that.
When dry, I sanded the parts with 400grit wet paper till smooth.
Then 99a black base coat, And two thick coats of clear.
