Originally Posted by burtandnancy
Littodevel, great to see your honesty here. 2 questions; what are you doing to prevent detonation and are lower compression pistons available? In theory, anything above 14.7 lbs boost = twice the hp. I'm waiting for your dyno results...
Not sure what I should call you.. Burt or Nancy so.. Burt and/or Nancy... heh Currently the only thing I could do is..
1) Lower the intake air temp charge...
2) Retard the ignition timing...
3) Lower the fuel temp going into the engine...
4) Install headers...
5) Install colder rated spark plugs...
6) Make the whole air fuel mixture richer...
This is just my experience with tuning other vehicles in the past, a few things I've currently done up to date was install headers and this allowed me to advance the ignition timing back up to gain more power but if I didn't do that, just by installing headers and lowering the exhaust temp would prevent some denotation but I personally used it to my advantage and increased the boost and advance the ignition timing haha.
The spark plugs in our smart is by denso and is a unique plug as it has a 12mm thread yet a 26.5mm thread length, denso's Irdium plugs don't come out for another 90 days... I might be looking at other plugs as currently i'm mis firing from probably all the knocking I've been doing to the engine, and after pulling the plugs out, they are wearing out.
I'm designing the water to air intercooler setup which should allow me to keep the intake charge lower to ambiet temp as much as possible, I've been able to reach the max 196 degrees under load, full throttle going up an incline on the freeway at around 10 psi of boost.
I modified the fan design and gave Tim over at SFR a new supplier for new fans and with this I installed 2 instead of 1 fan on the air/air intercooler... if you have no fans you could easily reach 250 degrees on the intake air temp which I've done as well. With two fans you can easily run the vehicle hard and it'll drop back down to a more stable 140-150 degree intake air temp under boost easily. You would really have to try to get the max intake air temp of 190 like I did and in the process there's a great chance you'll get a speeding ticket =P...
While crusing with easy throttle and no boost the intake air temp is around 112-118 on the freeway while being 55 degrees outside, ambient temp. On a hot day with it being 80 degrees out, my IAT (Intake Air Temp) is 139 with a/c on, light throttle and no boost.
I have a lot of data I collected and made my smart car do a lot of weird things but this is in the goal of having the ultimate turbocharged smart car while retaining the stock engine. And it also helps me be more then just sell and install these turbochargers for the smart car but also help other smart owners find better way to install the kit and be more of a technical assistant when one does run into an issue. Someone has to run into the issues first and being the one to run into them first, finding solution would allow me to be able to provide answers
Lower compression pistons are not available at the moment, they would be if I destoryed my engine... because then I would lower the compression ratio of the engine
Today I'll be ripping the front end off to see what is the largest heat exchanger (radiator) I could fit for the water to air intercooler setup.
Cheers!
Larry
