Old 06-16-2008, 08:46 AM   #1 (permalink)
Twin Fiamm Air Horns Install
1st thing I did after I took delivery of my car was to replace the single bosch electric horn. A very tight fit but after trying to find a power source for the relay, I just connected the two leads to the air compressor and since there is already a relay in the circut, it works just fine.
Now instead of the horn saying "Hello", I now says, "Get the F%&# out of my Way!"
The compressor mounted on the same tab as the original horn did and no cutting of any wiring is needed.
Charles
c20500 is offline   Reply With Quote
Old 06-16-2008, 08:54 AM   #2 (permalink)
Doug Thorley Ginuea Pig
SmartPassion's Avatar
Drive: 400E, S2k, Miata, smart!!
Did you get a chance to take some pictures?
Old 06-16-2008, 11:14 AM   #3 (permalink)
I'll get them up soon.
Old 06-16-2008, 09:04 PM   #4 (permalink)
Perhaps equally relevant to a horn installation picture is a recording of its sound. I had to hit the horn at someone the other day who was about to cut the corner off my front end, and the little thing more like a meow than a horn. It was rather embarrassing. Any chance you could upload a recording somewhere and provide a link here?
Old 06-16-2008, 10:04 PM   #5 (permalink)
The horns sound is exactly like the ones you hear on Italian cars... ie, ferrari, maserati Lamborghini, alfa romeo... a dual tone trumpet sound.
Old 06-16-2008, 10:15 PM   #6 (permalink)
Bring it to the Redondo Beach meet. We want to hear it in person.
Old 06-17-2008, 12:03 AM   #7 (permalink)
Smart Car Geek's Avatar
Ant idea on how loud it is in decibels?
Old 06-29-2008, 07:32 PM   #8 (permalink)
starlord's Avatar
Drive: 2008 smart fortwo passion
If it's the same horn i installed (you can get them at kragen) they come with 2 plastic red or chrome trumpets and output 118db
Here's the easy instructions for a dual-horn install..
[ standard disclaimer: i will say that i'm not a certified mechanic or electrician, and even if i were I would still say that you do this at your own risk, if in the process of installing you hurt yourself or your smart car its your own fault. if you have questions or don't feel confident that you can do this on your own, please ask a qualified person to do this for you. you have been warned! ]
step 1:
Go to the local autoparts store and get yourself a WOLO or Fiamm set of air horns. There's a two-horn package with one low and one high pitch horn, tubing, air compressor, relay, and some mounting stuff. You can get them in red or chrome plastic.
step 2: take the long length of tube and measure a 2.5" short peice, a 6" peice, and whatever is left. you now have cut the hose into 3 pieces.
step 3: open the bonnet lid by flipping the bottom grill snap things outward and lift the plastic bonnet out, place it in the holder so it stays put.
step 4: on the driver's (LHD) side below the brake fluid reservoir, locate the two wires from the stock BOSCH horn. There is one blue one and one brown. unplug these by carefully but firmly pulling the prongs off the stock horn
step 5: connect the 6" length of tube to the air compressor. If you do this first it will save you time later. Now wiggle the air compressor in past the top of the brake fluid reservoir, down and around underneath where the stock horn is located. Holding it in your hand, flip it over upside down so you can plug in the wires. Notice the polarity. Blue is positive, Brown is Negative. This is probably the hardest part of the whole install. If you look at the prongs and how they attach to the compressor it will make sense. You may need to force it in a bit if the connections are tight, but it will go in there.
step 6: Now that the compressor is connected you can connect the air horns to it. Drop the compressor down. Connect the bottom of the Y adaptor to the hose coming from the compressor. Connect the shorter 2.5" length of tube to the right Y and the longest length to the left Y.
step 7: connect the shorter horn to the short hose, and position it down so that it fits as shown in the photo. This is so you can easily close the bonnet back up when you're done, and it positions it down so that bugs and debris will be less likely to get in.
[Note: This is a good time to check the horn to make sure you wired it correctly. If you hear the motor running but no honk, the compressor is wired wrong. This doesn't hurt anything, it just means it's running backwards so wont pump out air. If the short horn honks, then you got it wired correctly and wonderful air is blowing through it.]
Some people like 1 horn, but 2 sounds more classic in my opinion, anyway.. onward..
step 8: run the longer tube under the thing, all the way through from one side to the other, as shown in the photo, then connect the larger horn to the end of it.
step 9: position the longer horn as shown so that it bends the hose into a slight U shape whilst keeping the horn in a good spot.
step 10: now you're good to go. close up and latch the bonnet, try our your new air horns!
(notice we didn't use the relay since your car has one built-in, and since this was the easy install, no mounting or screws or brackets or what not were used.)
There are larger versions of the pictures here for those that want to see them ;)
http://flickr.com/photos/miniology/s...7605889238804/
starlord is offline   Reply With Quote
Evil Twin Dual Center tip 380.00 BreathlessPerformance Performance & Handling 5 06-15-2008 07:42 AM
Dyno Testing Started Today, Exhaust Stock vs Evil Twin vs CES Performance Twin Center BreathlessPerformance Performance & Handling 18 06-09-2008 04:17 PM
Our Dyno testing Started today, Exhaust, Stock-Evil Twin- CES Twin center tip!! BreathlessPerformance Smart Car Modifications 39 05-30-2008 01:51 PM
Air horns jwight Smart Car Modifications 27 04-21-2008 03:58 PM
Twin Turbo V6 Roadster oldbike Smart Car Videos 1 01-21-2008 12:51 PM
