Old 02-16-2008, 10:53 AM   #1 (permalink)
Drive: Sable,Triumph Spitfire
unique Scangauge II install
I decided I didn't like stuffing the gauge in the cubby to the left of the steering nacelle. The spot I decided I like best is right below the switch panel (hazard, etc.) but the sticky velcro Scangauge provides was not going to work on the fabric covered plastic. I do not want to drill any holes, so here is what I devised:
http://home.everestkc.net/ckigar/scangauge.JPG
The silver discs are super strong rare earth magnets stuck on to the gauge with 3M double sided mounting tape. The mates to the magnets are on the other side of the panel, easily accessible by popping the switch panel out. The magnetic force is more than adequate to hold the gauge in position while using the buttons.
If you try this, exercise caution when handling the magnets as they can snap together with a hazardous amount of force. The ones I purchased were packed with separators.
ckigar is offline   Reply With Quote
Old 02-16-2008, 10:59 AM   #2 (permalink)
smarts@AF Museum!
Do you have to use a crowbar to remove it? Seriously, any effect on the display from the magnets?
Old 02-16-2008, 11:09 AM   #3 (permalink)
dancote's Avatar
Drive: 2009 Y/B/L Brabus Coupé
Nice Install
Thanks for the post. Where does the connector go? Is it on the side of the unit? Do you have a picture of that as well"
dancote is offline   Reply With Quote
Old 02-16-2008, 11:19 AM   #4 (permalink)
The connector has about a 14" run from the ODB II jack to the rear of the unit. Right now I just tucked the excess behind the odb II jack. In theory, you could shorten the cable with an fresh RJ45 and the use of a crimper. There is an available side plug on the unit, but the rear worked better here.
The strong maggggneeettticccc field seems to have no efffffffffffffffffect on the diiiiiisplay
Old 02-16-2008, 11:55 AM   #5 (permalink)
Looks very nice
Very clean install
Old 02-16-2008, 11:59 AM   #6 (permalink)
SmartAzz's Avatar
Looks nice Best to keep any iPods, watches, computers, etc a distance away though
Old 02-16-2008, 12:00 PM   #7 (permalink)
Administrator
SMART's Avatar
Drive: smart fortwo coupe
Very cool.
Old 02-16-2008, 12:23 PM   #8 (permalink)
Good point. These could definitely erase a hard disk.
Old 02-16-2008, 12:25 PM   #9 (permalink)
angel's Avatar
Drive: 08 smart fortwo blue/black
Wonder if there's enough room there to do that with a cb?
Old 02-16-2008, 12:26 PM   #10 (permalink)
Carnut's Avatar
Drive: Jetta TDI
Nice! Any ETA when they will have the 451 USA codes?
How difficult will a tach/clock install be? kags1969 Smart Car General Discussion 7 12-24-2007 07:42 PM
updated: where does the mpg scangauge look best? mr_Cash Smart Car General Discussion 5 12-02-2007 09:26 PM
white or black scangauge buttons look best? mr_Cash Smart Car General Discussion 7 12-02-2007 02:18 PM
