2014 smart fortwo passion with 15K Advice - Smart Car Forums
 10Likes
post #1 of 19 (permalink) Old 12-23-2016, 11:29 PM Thread Starter
Quoted: 4 Post(s)
Good Evening
I just found and put a deposit on a 2014 smart fortwo passion
We haggled a bit and test drove. The smile on my face when she got done with her test drive was priceless! The car seems fine during my test drive an air bag light came on and my wife noticed a brake light was out. I brought my OBD2 reader and while there was not check engine light on but it did have a code U0001 High Speed CAN Communication Bus. It was also missing part of the smart emblem on the back just "sma"
The dealer is just down the street from Benzel-Busch smart center Englewood, so they said they would bring it to them to have everything looked at as it was still under warranty.
The tire were fair brakes felt good but I assume at 15k they could be coming to the end of their life.
My questions are
Are there major concerns with what I have mentioned? Or just normal Smart things that crop up
Where is the wheel lug lock key kept?
Thanks for your time this forum looks great
vaccaro is offline
post #2 of 19 (permalink) Old 12-24-2016, 02:00 AM
Quoted: 152 Post(s)
Originally Posted by vaccaro View Post
Good Evening
Break light should be easy fix with bulb replacement. As for the SRS light, could be a loose connector under either seat for the seat side airbags - should be a fix under warranty.
Naughty children. Doubt dealer would replace. You can find the 'smart' letter decal online. Or just remove the 'sma'.
With the seller or prior owner. You will need that key, else that tire is staying put. No key would be a deal break for me.
And be sure the car comes with two working ignition key fobs - they are uber expensive to replace.
Happy Holidays everyone - and an awesome 2017.
jwight, Neonspinnazz and jzchen like this.
stevenjb is offline
The Following User Says Thank You to stevenjb For This Useful Post:
vaccaro (12-24-2016)
post #3 of 19 (permalink) Old 12-24-2016, 06:16 AM Thread Starter
Quoted: 4 Post(s)
Thank you! My wife's last car was a chevy aveo, we got that with 40K on it and it served us pretty well for the last 7 years now it still an okay car but there always worry related to it." will that dam timing belt break?"
We are hoping to get a great life from this little car.
vaccaro is offline
post #4 of 19 (permalink) Old 12-24-2016, 08:32 AM
Quoted: 480 Post(s)
The U0001 is a very common item, most likely caused by a phone charger with a bit of voltage left in it when the car was shut off. I would be more concerned about the tire locks
jimvw57 is offline
post #5 of 19 (permalink) Old 12-24-2016, 09:23 AM
Quoted: 252 Post(s)
I keep my wheel lock key in the glove compartment in front of the passenger seat. It could possibly be in the bottom door panel in the "trunk". Those things can be a pain to remove. I agree that you better find it somehow...
Benzel used to have a great www.smartonlineparts.com website. Seems like it's no longer there. I did check on Benzel-Busch's website, and the catalog was not there last time I checked...
jzchen is offline
The Following User Says Thank You to jzchen For This Useful Post:
post #6 of 19 (permalink) Old 12-24-2016, 09:47 AM
Neonspinnazz's Avatar
Quoted: 143 Post(s)
Good Evening
My questions are
Hiya!!!! Welcome to our lovely asylum!!!!!
To answer your questions:
1. Brake light: These cars sometimes have the tendency to eat bulbs, usually if the previous owner used them allllllllll the time. Easy to replace though.
2. Air bag light: Were any of the seatbelts jammed when the light was on? Sometimes if you take a corner at speed or pull too hard on the seatbelt, the SRS will lock the seatbelt and hold it for dear life until the light comes on. Lightly tugging will disengage the lock and the light will turn off on the next engine cycle. Either way, dealer ought to fix that, same with that CANBus error.
3. sma: Well, the emblems pretty much never fall off. Since it was obviously caused by some shenanigans with the previous owner and the burden shouldn't be passed onto you, I'd ask the dealer to replace... I mean, it is the car's badge!!!
4. Wheel locks: I assume this car has custom wheels, as I haven't seen any smarts with wheel locks outside a Brabus here and there and folks with custom wheels. Either have them find the key, or have the dealer extract that lug bolt out and replace with one that doesn't have a lock. Doubt they'll do it for free though.
5. Brakes/Tyres: Neither should be close to being worn out at 15k...however, if that car has custom wheels, it could be very possible.
Hope it all works out!!!
Neonspinnazz is offline
The Following User Says Thank You to Neonspinnazz For This Useful Post:
post #7 of 19 (permalink) Old 12-24-2016, 09:54 AM
Rustedwrench's Avatar
Quoted: 190 Post(s)
Either the timing belt will break or one of the guide pulleys will fail and turn the engine into junk if they are not replaced with oem or equal quality parts. The only question is, when will they fail.
Rustedwrench is offline
The Following User Says Thank You to Rustedwrench For This Useful Post:
post #8 of 19 (permalink) Old 12-24-2016, 10:45 AM Thread Starter
Quoted: 4 Post(s)
Thank you all for your in-depth answers. You have made this a much nicer decision
vaccaro is offline
post #9 of 19 (permalink) Old 12-24-2016, 10:48 AM Thread Starter
Quoted: 4 Post(s)
here is the car. It does look like stock rimes, in the picture it looked like there were special keyed lug nuts
2014 Smart Fortwo PassionCOMFORT PACKAGEPANORAMA ROOF In Hasbrouck Heights NJ - C&K Auto Imports
We should pick up the Car on Tuesday! WOOT. Ive dealt with quite a few used car dealers but they seem okay, hopefully they will have addressed those few issues.
Again thank you for taking the time.
vaccaro is offline
post #10 of 19 (permalink) Old 12-24-2016, 11:00 AM
Quoted: 252 Post(s)
Just took a peek at the ad. Those look like the standard 15mm lug nuts. It was blurry... (The standard lugs had hollow centers, I'm assuming so the wheels could break away in an accident. The OE locks have a similar design feature if I recall correctly.)
McGard sells locks for the standard wheels, and aftermarket wheels had a tendency to use the OE bolts?.?. Those definitely look like OE wheels.
Sent from my iPad using Tapatalk
kheran likes this.
jzchen is offline
Human Verification
331
2014 Smart Passion Fortwo in the Studio for Comparison Photos and Testing! Diode Dynamics Diode Dynamics 6 05-18-2015 10:38 AM
A review of the 2014 (?) smart fortwo Toolman smart General Discussion 30 11-06-2013 06:19 PM
For Sale: 2008 Smart fortwo Passion in metallic red FOR SALE!!! ONLY 15k MILES!!! RedSmartCar smart Vehicle Marketplace 0 08-01-2012 09:58 PM
For Sale: 2009 Passion - 15k Miles - $11,000 (price reduced to $10K) zebra5150 smart Vehicle Marketplace 32 10-19-2011 02:21 PM
2009 passion w/$15k in extras. Ipad installed! soundsfast Archive/obsolete (?) threads 3 02-10-2011 05:22 PM
