Fuel Efficiency Improvements - Smart Car of America Forums : Smart Car Forum
Old 08-08-2008, 07:28 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Greetings! I just got my smart a week ago and it becomes apparent as I drive it a lot that the automatic transmission on "D" does NOT give a good fuel efficiency. Does anyone have tips on how to best drive the smart for maximum fuel efficiency???
Thanks!
YOURS Stefan
stefanhermann2003@yahoo.c is offline   Reply With Quote
Old 08-08-2008, 08:08 PM   #2 (permalink)
Dave777's Avatar
Put it in D and drive with a light touch. Works fine that way.
Old 08-08-2008, 09:19 PM   #3 (permalink)
lowndex's Avatar
Lots to read on this subject.
Do your own search/es on driving in D, Smart transmission, etc.. You will find a wealth of advice how to drive and yield best mpg.
Old 08-08-2008, 09:21 PM   #4 (permalink)
Dean Smith's Avatar
Don't forget that this car has a break-in period. The first 1000 miles its a slow dog, but gains Greyhound qualities at about 3000 miles. Even my steering has loosened up, and it shifts much better now. My mileage has fluctuated between 24 and 42, depending on heat and air conditioning. Palm Springs is running about 112 degrees every day...and that takes a big toll on performance.
Dean Smith is offline   Reply With Quote
Old 08-09-2008, 05:49 AM   #5 (permalink)
Feral_Collie's Avatar
Here's my two cents regarding fuel efficiency:
1. Be in a good mood. If you're calm, oriented, and alert, your speed will fluctuate less, thus decreasing consumption.
2. Don't be in a hurry. Give yourself plenty of time to get to your destination. If you're running late, you're gonna run a red light at 15 over the speed limit then slam your brakes on the other side of the intersection just to save 30 seconds of waiting for the next green. Doesn't help your cause.
3. Premium fuel is a must. Even in the Wife's Jeep, we use premium, and my own experience shows anywhere from 2 to 5 mpg of a difference. May or may not be cost effective, but you spend less time diverted to a gas station.
4. Light acceleration, speed limit. These are a beaten, dead horse.
5. Anticipation. If you're a fair distance from a green light in a city, you're probably not gonna make it, so you might as well coast if you know it's gonna turn red. Coasting will cause the mixture to lean out, and the engine's inertial dampening will help you decelerate.
6. Clean air filter, proper tire inflation. More from a dead horse.
7. Good oil. Don't buy the "99 cent special" motor oil from walmart. Use a synthetic that has been independently tested for high film strength. These oils are slicker, with smaller molecules, granting greater lubrication with less parasitic drag.
8. Keep it clean. May sound silly, but a dirt covered vehicle is less aerodynamic, which can account for a lot.
There's a couple more I've tinkered with, but unless you've studied Organic Chemistry, I'd probably lead you astray. I hope these helped!
Feral_Collie is offline   Reply With Quote
LinkBack to this Thread: http://www.smartcarofamerica.com/forums/f2/fuel-efficiency-improvements-12362/
SMART CAR PICTURES: The smart fortwo can be flat-towed This thread Refback 08-08-2008 07:47 PM
Fuel Additives tishpit smart General Discussion 1 07-25-2008 05:16 PM
a/c efficiency cc238 New Members Area 16 04-22-2008 01:07 AM
F Y I on Fuel ASmartMan smart General Discussion 15 03-25-2008 03:20 PM
Hi fuel use Jon Lewis smart fortwo (451 - US vehicle) 12 01-17-2008 01:19 AM
On Bio-fuel Old smart The Car Lounge 13 11-11-2007 04:35 PM
