Horn Problem - Smart Car of America Forums : Smart Car Forum
Old 07-29-2009, 02:41 AM   #1 (permalink)
Horn Problem
Hi.....I am very new to this site and hope you will forgive any mistakes.First Hello to all across the Pond and I wish you all well...I have a Smart Car in the UK which has a horn problem and have been told that the problem is with the steering wheel which requires replacement to cure the problem.....It seems there is no circuit between the SAM unit and the steering wheel and hence the horn relay is not clicking when you press the steering wheel....Has anyone ever heard of this.
john143 is offline   Reply With Quote
Old 07-29-2009, 06:18 AM   #2 (permalink)
Owner for 3.8 years
Kermit's Avatar
450 or 451. As far as reported 451 horn problems here on this site, most have been just a blown fuse but I recall someone having a bad relay once too.
Old 07-29-2009, 07:35 AM   #3 (permalink)
sato7's Avatar
why would the relay be in the steering wheel? that sounds real bogus. check fuses, and WHERE the horn relay is located.. changing a relay is 3-4 dollars (2-3 pounds) changing the steering wheel PLUS labour.... OUCH!!
Old 07-29-2009, 11:06 AM   #4 (permalink)
SubSlr88's Avatar
And don't forget the airbag is in the steering wheel - dangerous to mess with that without disconnecting the battery; just in case.
Find the relay on the panel - replace it. Might want to check the horn connections, too. May be a poor ground or other loose connection. Lots of things to check before diving into pulling the steering wheel.
Horn kip123 New Members Area 29 08-27-2011 03:37 PM
Wonder what you think about mounting this horn yellow smart smart General Discussion 24 05-06-2009 03:27 AM
Horn problem billypeggy smart General Discussion 11 05-04-2009 05:51 PM
Air Horn smartfloridadad smart Modifications 3 08-22-2008 08:17 PM
Fanfare Horn Old smart Interior & Exterior 17 06-14-2008 08:21 AM
