light bulb burnout? - Smart Car of America Forums : Smart Car Forum
Old 05-11-2008, 01:34 PM   #1 (permalink)
light bulb burnout?
Hi my name is Pierre and I have had my smart car for three and half years (Canada). It is a Black cabrio passion with a silver frame. The car is great on gas but hard on light bulbs. I have replaced 3 complete set of headlights, five tail/brake/signal in the back. Has anyone else experienced so many burnt out bulbs.
ptrottier is offline   Reply With Quote
Old 05-12-2008, 10:38 AM   #2 (permalink)
bull8042's Avatar
Hello and welcome Pierre. I have had my smart for 3-1/2 days, so it is a little difficult for me to comment on the bulb issue. Hopefully, someone with a little more history will be along shortly and help you out.
Old 05-12-2008, 11:34 AM   #3 (permalink)
Pierre - Start your smart and drive until the engine is warmed up to operating temperature. With you car in PARK and running above idle, ~2000rpm, measure the voltage at the 12V recepticle in your car with an analog meter. It should be below 14.5 VDC and be steady. Switch the meter to the A/C scale and check for ripple. If AC is present there could be a problem with the alternators voltage regulation or unrectified AC causing the lamp failure. Just a guess!!! Good Luck!!!
SRS Indicator Light SmartCab08 smart General Discussion 47 10-25-2011 06:08 PM
2008 Smart ForTwo Headlight Bulb Model Question evsmotors smart General Discussion 27 12-20-2010 01:49 PM
SRS Light on Foozy smart Operation and Maintenance 14 07-26-2010 09:26 PM
Light at the end of the tunnel? skyzdlimit59 smart General Discussion 2 02-15-2008 04:27 PM
