Rear Wheels on the Front? - Smart Car of America Forums : Smart Car Forum
Old 10-29-2008, 03:00 PM   #1 (permalink)
When I took delivery of the car I asked the dealer if I could put a set of the wider rear wheels on the front as well. I was told it throws the balance of the car off. Anyone know if this is actually true?
The dealer also told me this would void the warranty...is that true?
runflat is offline   Reply With Quote
Old 10-29-2008, 07:55 PM   #2 (permalink)
Not Selling on Ebay
Offsets are different front to rear. Wider tires are available. Check out the "Pulse" model on one of the european smart sites. On the Pulse the 175's are on the front and 195's are on the rear. They do not use the rear wheels in this instance. They use wider front wheels with the proper offset.
Old 10-29-2008, 08:11 PM   #3 (permalink)
SmartDigger's Avatar
I can't see how that would void the warranty.
Old 10-29-2008, 08:16 PM   #4 (permalink)
cervixsmasher's Avatar
There are laws to protect consumers in regards to aftermarket mods and voiding warranties. The warranty can't be voided unless the damage was caused by a mod you had done to the car.
cervixsmasher is offline   Reply With Quote
Old 10-29-2008, 08:20 PM   #5 (permalink)
Not Selling on Ebay
Changing offset by putting rear wheels on front will cause wheel bearings to fail prematurely. Take car back to dealer to have it fixed and they'll tell you to take a hike.
Old 10-29-2008, 08:22 PM   #6 (permalink)
I guess the answer is to get the tires and wheels you want but always put the stocks on when visiting the dealer!!
Old 10-29-2008, 09:08 PM   #7 (permalink)
smart fortimo's Avatar
Devious, Dunerunner
Old 10-30-2008, 03:35 AM   #8 (permalink)
fmaxwell's Avatar
The fortwo has different sized wheels to minimize rollover and to account for the RWD/rear-engine design from a handling perspective. The initial introduction of the smart was delayed while Mercedes addressed the rollover problem. One aspect of the fix was narrower front tires.
Old 10-30-2008, 04:39 AM   #9 (permalink)
Same size tires on front and back?
Interesting coincidence. Just yesterday I went to the Tirerack website and saw that their recommended snow tire size for the 2008 smart car was the 175 for BOTH front and back. I immediately called their Technical Support people and told them to research that recommendation since I thought they would be open to some liability. (If that combination would work, why in Heaven's name would smart go through the trouble of putting two different size tires on their stock vehicles, I explained). Further confusing the issue was Tire America's recommendation for the two DIFFERENT size tires on our 2004/2005/2006 European converted smart cars in the US, just like the stock vehicles. Not sure, but I imagine Tirerack's recommendations should change on the 2008's sometime later this week... but maybe not, based upon the other feedback in this forum...
Ron Gaus, aSmartCar.com, St. Louis
rgaus is offline   Reply With Quote
Old 10-30-2008, 10:57 AM   #10 (permalink)
Supporting Tuner
Evilution's Avatar
Originally Posted by mfoster View Post
Changing offset by putting rear wheels on front will ..........
The maximum difference in offset between the front and rear 451 alloys is 1.5mm. This much offset change will not increase bearing wear at all.
Extra weight will reduce the operational life of the bearings (but we are talking weeks), luckily the bearings are a 10 minute job.
__________________
Road rash on front of rear fenders stardaug smart General Discussion 9 06-28-2011 08:08 PM
451 Front + Rear Brake Pads FMSI? VinceLA smart Operation and Maintenance 15 10-04-2009 11:39 AM
Front, top, sides and rear window shades LittleDeuceCoupe Interior & Exterior 9 09-16-2008 08:14 PM
anyone instal front and rear bumper guards? curtis smart General Discussion 12 06-15-2008 02:30 AM
weight distribution front/rear? pattison smart Operation and Maintenance 4 06-08-2008 09:38 AM
