453 first oil change at 2000 miles - Page 2 - Smart Car Forums
 36Likes
post #11 of 89 (permalink) Old 02-17-2016, 04:10 PM
Gortok's Avatar
Quoted: 22 Post(s)
Looks like it's a 8mm square plug drive. They have a set 4,6,8 and 10.
5/16 would most likely work, but it's a tad small and might "dink" the inside of the square.
Got the 8 on the way...
IF it turns out to be some crazy crap like 8.5 or 9, I'll let you know...It wouldn't surprise me tho'...
jwight and OliverB like this.
Gortok is offline
The Following User Says Thank You to Gortok For This Useful Post:
jzchen (02-24-2016)
post #12 of 89 (permalink) Old 03-23-2016, 02:45 PM
Gortok's Avatar
Quoted: 22 Post(s)
It is indeed 8mm.
The tool I got is from HAZET (Germany) model no. is 3702...
They are available on Fleabay.
jwight likes this.
Gortok is offline
jzchen (01-01-2017)
post #13 of 89 (permalink) Old 03-23-2016, 03:20 PM
Quoted: 166 Post(s)
Originally Posted by Gortok View Post
It is indeed 8mm.
Yep, sure are. Bought one too and did my first oil change last week.
OliverB is offline
post #14 of 89 (permalink) Old 03-23-2016, 04:27 PM
Quoted: 3 Post(s)
CTA Tools 2036 is a 3/8" to 8mm square adapter. This is availble on line, Sears, walmart, etc
mtnsmart is offline
The Following User Says Thank You to mtnsmart For This Useful Post:
jzchen (01-01-2017)
post #15 of 89 (permalink) Old 03-23-2016, 09:55 PM
Quoted: 77 Post(s)
Is the 453's oil filter able to be accessed with all tires on the ground? (Sliding under car on one's back to reach at the filter area).
White Lightning is offline
post #16 of 89 (permalink) Old 03-24-2016, 06:19 AM
Quoted: 166 Post(s)
I have reached it without raising the car while checking out the size socket I needed to remove the filter but it is a tight squeeze. I use a pair of 2x6s to drive up on for a bit more clearance.
OliverB is offline
The Following User Says Thank You to OliverB For This Useful Post:
White Lightning (03-24-2016)
post #17 of 89 (permalink) Old 03-24-2016, 12:38 PM
Quoted: 77 Post(s)
Thanks for the reply. With the tight squeeze, do you think there would be enough "elbow room" to undo, drain, and replace the 453's oil filter (while all four tires are on the ground)?
OliverB likes this.
post #18 of 89 (permalink) Old 03-24-2016, 02:28 PM
Quoted: 166 Post(s)
Not certain about that as I didn't replace the oil filter on my first early miles oil change. Just a guess but it could be a bit messy with confined space limited even more by a drain pan.
OliverB is offline
post #19 of 89 (permalink) Old 03-24-2016, 02:35 PM
robjla's Avatar
Quoted: 33 Post(s)
Planning on doing the early change as well. Glad to see people doing it. IMO it's always good to do when you're breaking it in
Sent from my iPad using Tapatalk
robjla is offline
post #20 of 89 (permalink) Old 03-24-2016, 02:43 PM
Quoted: 146 Post(s)
I'll probably do an early oil change as well. The yearly service schedule is a bit too long for my liking.
robjla likes this.
matt_453 is offline
Human Verification
331
Oil change, 5000 miles... mattwithcats smart Operation and Maintenance 3 03-12-2011 06:17 AM
Why is it needed to change the oil within the 1st 100 miles vs 3K 2micro4u smart Operation and Maintenance 144 11-15-2009 08:16 AM
oil change - how much time (not miles) britboy smart General Discussion 9 07-15-2009 04:27 PM
2008 Smart For-Two Under 2000 Miles SylenThunder Archive/obsolete (?) threads 2 03-13-2009 08:26 AM
3 Months and 2000 miles later- Duckhunter smart Operation and Maintenance 3 12-21-2008 06:44 AM
