453 oil type? - Smart Car Forums
 14Likes
post #1 of 76 (permalink) Old 04-13-2016, 03:09 PM Thread Starter
skoone68's Avatar
Quoted: 28 Post(s)
453 oil type?
OK so I'm a dummy and my constant site searching is turning up 0 results.
Please answer: Does the 453 use 0w40 engine oil like the earlier models?
Thanks
-Steve
skoone68 is offline
post #2 of 76 (permalink) Old 04-13-2016, 03:55 PM
Quoted: 68 Post(s)
Pretty confusing...
From the manual:
All models 229.51, 229.53
From the Mercedes Bevo site:
229.51 Low SPAsh multigrade service engine oils (Specification 229.51)
229.53 isn't listed....?
Mobil 1 Euro formula 0W 40 is on that list.
smart USA always recommends consulting your smart center - not sure why they just don't give the recommended oil(s) specs to the owners up front.
jwight is offline
post #3 of 76 (permalink) Old 04-13-2016, 06:18 PM Thread Starter
skoone68's Avatar
Quoted: 28 Post(s)
Agreed. I wish they would simply spell it out for us simple minded folk.
I saw the "Bevo" info, however, since it didn't make any sense to me, I thought it better to ask here. You guys are the best resource and FAR more helpful than trying to beg for info like this from my local service center...
Thanks for the clarification.
-Steve
skoone68 is offline
post #4 of 76 (permalink) Old 04-14-2016, 05:19 AM
Quoted: 287 Post(s)
Here's a link to a sheet that nearly covers every Mercedes vehicle:
http://bevo.mercedes-benz.com/d/d/en/Spec_223_2.pdf
Just a quick glance a the dots, note that 229.51 is more for diesel vehicles with diesel particulate filter.
Under "Gasoline Engines - Worldwide (except Western Europe) -"
please note that 229.5 seems to be the specs to follow...
Very confused???
I read the 2016 manual available on www.smartusa.com and found the 229.51 and 229.53, but but but???
Mercedes is definitely not being consistent!
Look at this!!!
https://mobiloil.com/en/motor-oils/mobil-1/mobil-1-esp
For diesel. Something definitely isn't right....
Mobil 1 ESP 0W-40 is on the 229.51 list
Mobil 1 0W-40 is on the 229.5 list...
jzchen is online now
post #5 of 76 (permalink) Old 05-13-2016, 12:34 PM
Quoted: 287 Post(s)
Since people popping into these forums might search and find this thread, I thought I'd update that the motor is M 281, and the oil specs 226.5 and 229.5 are to be followed globally, and if your smart happens to be refueling in Western Europe 229.3 can be used. BEVO sheet is dated 01/2016, while the owner's manual is dated "As at 10.04.2015" on page 2, the "Publication details" page....
post #6 of 76 (permalink) Old 05-15-2016, 05:12 PM
Paul Va's Avatar
Quoted: 20 Post(s)
What oil filter do i have to get for 453 or just insert ? Thanks
Paul Va is offline
post #7 of 76 (permalink) Old 05-15-2016, 05:24 PM
Quoted: 287 Post(s)
I believe it is the insert, going by your location.
Paul Va likes this.
post #8 of 76 (permalink) Old 05-15-2016, 05:35 PM
Quoted: 68 Post(s)
US 453s have the 898cc turbo engine - should be in the specs section of the owners manual....
jwight is offline
post #9 of 76 (permalink) Old 05-22-2016, 06:29 PM
Quoted: 12 Post(s)
It's not.
I went through every page of the manual. It tells you to use "Mercedes recommended oil" and does not list the type of oil to use.
foxmajik is offline
post #10 of 76 (permalink) Old 05-22-2016, 06:46 PM
Quoted: 68 Post(s)
I was referring to Paul Va's question about the oil filter, not the oil.
jwight is offline
Human Verification
331
453 Oil Filter jbjinturner smart General Discussion 9 02-10-2016 04:34 PM
453 oil check OliverB 453 0 12-26-2015 04:51 PM
453 Oil Filter Location Okie Boy 453 7 11-30-2015 03:50 PM
Oil type help. smartyone smart General Discussion 46 12-17-2011 05:48 PM
What type of engine oil do I have to use? arakoh smart Operation and Maintenance 8 02-11-2011 07:40 PM
