Originally Posted by NCC1701
I'm guessing I'm out the $120 I paid for installation.
I wouldn't look at it that way NCC. The hardest part of the Area 451 install is running the cables and changing the pins in the connector block. That's the majority of where the labor cost probably came from, and none of that needs to be undone or re-done for the recall/repair.
My understanding of how they handle this is to send you a patch cable to replace your unit while it's shipping. You then ship the unit back to them, they reprogram it and send it back to you. All you need to do is disconnect a couple of plugs from the board and put a patch cable in it's place. (And do the reverse to replace the board after the repair.) If you can use an extension cord, you can do this
minor maintenance on your own. The only side effect is that you're without cruise for the time it takes to ship/update things.
The real question is
when is it worth the hassle to you to repair this minor issue. If you have a week where you know you won't be needing cruise coming up, you can probably delay returning it until then for repairs.
