Originally Posted by Allargando DiFortissimo
From what I've been able to find out, unless it's overheated (literally "cooked"), oil doesn't wear out. Only the additive package does. The oil could become diluted with gasoline, either burned (carbon) or unburned (essentially a solvent), but synthetics are incredible at holding the junk in suspension. Amsoil is, by all accounts, good stuff, but it's not going to make my street car engine last longer.
ADiF
Absolutely a 100% false statement. Also 100k miles on a car is NOTHING for Amsoil.
If you change the oil every 3000 miles with dino oil and it takes 6 quarts of oil, that's 33 oil changes x 6 quarts and 33 oil filters.
What is wrong with doing the same thing with 30 quarts of oil and 5 oil filters?
You're obviously picking dino oil to be cheap. Well, if you want to be cheap, then Amsoil is the way to go. You're not thinking long term.
There's no reason why you can't keep a car to 300,000 to 400,000 miles. Stop buying crap cars that you get bored of. Buy a car you REALLY enjoy and keep it to at least 200,000 to 250,000 miles before you get rid of it. New cars are not $2,000 to $5,000 anymore. I don't understand how people can spend $20,000 to $40,000 on a car and then have to complain about the cost of oil and then try to come up with all kinds of dumb reasons to use cheap oil that is costing them more money in the long run.
Why are you not doing the math?
Jiffy Lube @ $25 and oil change x 33 oil changes every 100k miles = $825
Amsoil @ $60 an oil change x 5 oil changes = $300 (and that's not factoring in the 2 to 4 MPG fuel increase which I've gotten in every single car I've ever used it in.)
So you're basically trying to convince me that I should use a lower quality oil that's going to cost more money long term and fill my engine full of waxes and parriffins. WHAT ARE YOU SMOKING?!?!?!
Remember, I was not using Amsoil from the get-go. For almost 20 years I used Castrol, Valvoline, Havoline, Mobil 1 and other stuff. I had no idea back then. I thought oil was oil.
Well, after a few experiences with switching to the Amsoil oil and ATF, I soon learned that there was a HUGE difference. If you ever saw that movie, "The Matrix", breaking out of that 3,000 to 5,000 mile oil change is sort of like the same thing. You're brain-washed to do those intervals because the oil companies are selling you those low quality oils and sell you tons of it. They are getting nearly 200 quarts of oil for every 100k miles of driving from you and laughing all the way to the bank.
My question is, WHY??!?! When you can do the same thing with Amsoil and only use 24-30 quarts and have the engine be in brand-new condition at 100-200k miles?
I saw a Ford van go 950,000+ miles on Amsoil. They took apart the engine and it only had 1% wear!!! And that's changing the oil ONCE EVERY 25,000 miles.
Stop being so close-minded. Try it. Do the 1-year drive and if you don't like it, switch back to what you were using before.
BE OPEN MINDED! I always am... not just for oil, but for many other products such as speakers, amps, tires, radios, surround sounds, TV's, etc. If you have something better than I'm using now, I'm always open for suggestions. I'm not loyal to any brand. There's no reason to be.
Those crap excuses of, "well, my daddy's been using it and my grandpappy's been using it before him, so I'm going to use it , too" is nothing but a huge cop out.
If everyone thought like this, we'd all be using 8-track tapes and never got into CD's or iPods.
