12V Port dead. A fuse? - Smart Car of America Forums : Smart Car Forum
Old 01-26-2009, 10:41 AM   #1 (permalink)
Been smart for 3.59 years
NCC1701's Avatar
All I've used the port for was powering a notebook, an air compressor, a power inverter. Oh, and a cigarette lighter.
The port is dead. I'm guessing a blown fuse. Haven't noticed anything else unpowered. Does the port have its own dedicated fuse? If so, which one is it?
I checked the online manual. It only goes through fuse #20.
Old 01-26-2009, 10:55 AM   #2 (permalink)
#21 for the 12v outlet: Evilution - Smart Car Encyclopaedia
Old 01-26-2009, 11:03 AM   #3 (permalink)
NCC1701's Avatar
Thanks jwight! I'm embarrassed that I didn't think of that resource.
Old 01-26-2009, 12:04 PM   #4 (permalink)
The OM does says a max draw of 5 amps is permitted from the 12 volt outlet. Might want to check the power draw of stuff like your inverter.
Old 01-26-2009, 12:09 PM   #5 (permalink)
My guess would be the cigarette lighter
BIG power draw
Old 01-27-2009, 09:00 PM   #6 (permalink)
5 amps at 12 volts is only 60 watts... not even enough to power a laptop (60-150W typical) with an inverter (70-90% efficiency typical). Very likely a fuse issue... can't imagine why they made it such a weak circuit. If we're going to power something it may as well do more than light up a book.
Old 01-27-2009, 09:04 PM   #7 (permalink)
NCC1701's Avatar
If what you say is true, that could explain how I blew the fuse. But, I'd used the car to power my notebook quite a lot before the problem surfaced. For what it's worth, the fuse is 15 Amp.
Old 01-27-2009, 09:21 PM   #8 (permalink)
The 5 amp "limit" came from page 165. Seemed low to me too, but there it is.
Old 01-27-2009, 09:33 PM   #9 (permalink)
NCC1701's Avatar
Is it possible that is a typo? I'm in the printing industry and see typos every day I work. Ok, probably not a typo ... I'm not too swift when it comes to electronics. Why the 15 Amp fuse for a circuit rated for 5 Amps?
Old 01-27-2009, 09:40 PM   #10 (permalink)
Laptops vary widely in their power requirements... my wife's comes with an 80W power supply, which at 70% inverter efficiency (a cheap one) would consume about 115W or 10 amps @ 12V. More advanced hardware will take more power, obviously. You may consider buying a Kill-A-Watt device - plug it into a 120V AC socket, plug whatever you want to measure into the KAW, and it'll show you how much power it's consuming - instant and over time.
The 5 amp limit is also shown on my "power port cover" which looks an awful lot like a plastic cigarette lighter. I'm guessing the written 5 amps was to allow for someone that plugs in 10 amps thinking it's close enough.
Additional fuse locations jwight smart Operation and Maintenance 2 01-06-2009 05:29 PM
Fuse box adapter jwight Audio & Video 8 09-16-2008 08:53 PM
Fuse box on 451 dbatch1715 Interior & Exterior 3 06-10-2008 06:45 AM
Brake Lights & Fuse Old SGM smart General Discussion 5 05-22-2008 07:01 PM
Horn Fuse (amps)? brian r smart Operation and Maintenance 3 03-10-2008 11:40 AM
