2009 Brabus Coupe - Wheel Nut Torque? - Smart Car of America Forums : Smart Car Forum
Trailer
Old 10-30-2009, 12:05 PM   #1 (permalink)
...just got a Silver Brabus Smart.... Cannot find any info on the Brabus "Monoblock VII" alloy wheel nut torque specs.... the manual indicates 80 lbs. for steel wheels (which is down from what the '08 manual stated (81 Lbs.).... no mention of alloy wheels at all. Does anyone have any idea? Thanks.
pagja is offline   Reply With Quote
Old 10-30-2009, 05:23 PM   #2 (permalink)
SmartDigger's Avatar
my passion with alloy rims is 81 # It is an 09
Old 10-30-2009, 06:12 PM   #3 (permalink)
silverbrabus's Avatar
Proper torque applies to the fastener. Wheel type will have no effect. Follow factory spec.
Old 10-30-2009, 09:12 PM   #4 (permalink)
Factory spec is 110 NM or about 84 lb ft.
There's always an acceptable range for wheel lug nuts but SMART doesn't provide that. I don't know if torque specs are different for bolts or not. Most likely anything from 75-85 lb ft is OK.
Be certain to clean the treads of the bolts, do not use any lubrication on the bolt or ball seat of the bolt. Torque specs for wheel lug nuts and bolts is for "dry" fasteners only. It is permissible and probably a wise idea to use anti-seize on the center ring area and the points where the wheel contacts the hub surface to prevent corrosion and difficulty removing the wheel.
Old 06-01-2010, 12:21 PM   #5 (permalink)
Other bolt torques?
Anyone know the bolt torque on the 12mm wishbone mount bolts? Thanks.
CaraVellair
CaraVellair is offline   Reply With Quote
Pucks & Wheel Torque for Commercial Tire Stores ulflyer smart Operation and Maintenance 7 10-21-2009 08:37 AM
Smart : Smart Brabus Coupe Brabus Coupe Smart Fortwo Brabus Passion Coupe Smart Cars For Sale Archive/obsolete (?) threads 0 05-25-2009 11:20 AM
2009 Brabus Coupe Available Now @ Ray Catena smart center Edison smartcenterEdisonNJ New Jersey Chapter 3 01-22-2009 12:19 PM
2009 Brabus Coupe Available Now @ Ray Catena smart center Edison smartcenterEdisonNJ New York Chapter 4 01-22-2009 12:09 PM
2009 Brabus Coupe Available Now @ Ray Catena smart center Edison smartcenterEdisonNJ North-East Region 1 01-19-2009 02:34 PM
