If I remember correctly, a high percentage of 450 MB engines pooped out near 80K - the reason was an issue with the valves. The company instituted prevention type maintenance - check the valves at 60K - and this for the most part solved the problem. Now if the maintenance checks are done on the valves, coolant level, regular oil changes at I think 10K (working from memory here) then the Smart 450 happily hums along well into old age, above 120K. We'll have the Mitsubishi engine here, so we'll likely start with the same maintenance program and we'll likely have the same success.
