Air Conditioning not charged in new 2009 - Smart Car of America Forums : Smart Car Forum
Trailer
Old 06-27-2009, 06:19 AM   #1 (permalink)
A/C not charged in new 2009 Smart Passion. Anyone else had this problem? Purchased at Loeber, Lincolnwood
Not charged from factory? Does it happen in shipping? Do I have a leak?
Loeber recharged 06/26/09...
I'll check the temp at vent in about a week or 2. I'll let you know what happens.
smart e pants is offline   Reply With Quote
Old 06-27-2009, 12:17 PM   #2 (permalink)
brett2658's Avatar
a/c
you may have a leak because the call would be checked at the factory when there would do the final check before they take the car out of the factory.
brett2658 is offline   Reply With Quote
Old 06-27-2009, 12:27 PM   #3 (permalink)
JOIN SCOA.YOU'LL BE GLAD
..have a vacuum check run on the system to verify zero leaks..
...make sure the A/C compressor is coming on..
jetfuel
Old 06-27-2009, 04:54 PM   #4 (permalink)
Macaw's Avatar
Had the same problem on a new '89 accord and 2001 Tracker both were loose fitting from the factory.
Old 06-29-2009, 05:50 PM   #5 (permalink)
Just started seeing this, has only happened on 2 of our cars so far.
smartSEATTLE is offline   Reply With Quote
Old 06-29-2009, 08:09 PM   #6 (permalink)
Red Roller Skate
fpage77's Avatar
With this issue is the AC not getting cold at all or is it only slightly cool?
Old 07-02-2009, 02:42 PM   #7 (permalink)
A/C control head issues
At 5300 miles the SRS light came on. I brought the 2009 Passion in for service. While checking the SRS light the tech also found that that the A/C control head needed replacing. This is what the tech wrote. Hard fault stored in the computer system stating a/c temp control module is faulty. Scaned system, removed unit and installed new temp control module, rescaned system and everything was ok. I thought the A/C was lacking, I just figured that that was the way it was designed, what do I know!
Fricassee is offline   Reply With Quote
Old 07-02-2009, 04:09 PM   #8 (permalink)
dealer refilled and works great now.
I'll see how long it blows cold for.
going to get a temp on the air at the vent and recheck in a week or two.
Problem with Air Conditioning (450) jason smart Operation and Maintenance 1 06-05-2009 03:35 PM
Air Conditioning detailjoe smart General Discussion 10 07-26-2008 02:48 PM
MPG Hit -- Top Down vs Air Conditioning Prospero smart Operation and Maintenance 3 07-10-2008 09:55 AM
Air Conditioning and gas mileage? Docthrock smart Operation and Maintenance 23 05-04-2008 07:44 PM
Air Conditioning choppermike smart General Discussion 3 10-02-2007 06:58 AM
