Air Filter Removal - Smart Car of America Forums : Smart Car Forum
Old 02-16-2009, 01:09 PM   #1 (permalink)
jonmills's Avatar
Air Filter Removal
I know there have been numerous threads on this topic. I am trying to install a new air filter. I unfastened the three clips and unscrewed the clamp but I cannot get the piece attached off of the top of the filter box. What is the trick?
jonmills is offline   Reply With Quote
Old 02-16-2009, 01:19 PM   #2 (permalink)
hot engine and a piece of broomstick to pry it off. It worked for me.
arude is offline   Reply With Quote
Old 02-16-2009, 01:37 PM   #3 (permalink)
JimDantin's Avatar
Pull the intake pipe off of the filter box -- then the top pf the filter box is easy to remove. When reattaching, slip the pipe onto the top before you lock the top down.
If you are fighting it, stop and figure out what's wrong -- if you're doing it right, it's pretty easy. I have the bloody knuckles to prove that statement!
Old 02-16-2009, 01:51 PM   #4 (permalink)
Commander Cody's Avatar
JimD is soo right. After my bloody knuckles I realized you had to reattache the hose to the top of the box and then go about installing. Take Note: when you're putting the top of the box back on make sure that the plastic tabs that are on the rear of it go into the respective holes. If you don't the fit won't be secure and you'll be pulling in unfiltered air!
Commander Cody is offline   Reply With Quote
Old 02-17-2009, 05:35 AM   #5 (permalink)
jonmills's Avatar
I got the reattach part. I can't get the intake pipe off.
Old 02-17-2009, 06:31 AM   #6 (permalink)
Evilution indicates that it will take some effort: Evilution - Smart Car Encyclopaedia
Old 02-17-2009, 10:51 AM   #7 (permalink)
Macaw's Avatar
pop off clamps, loosen clamp. Lift up at front pull forward just enough to disengage rear clips. At this point the top is loose. lift up front and back slightly and shove it backwards as far as it will go. The intake hose should be easy to remove now.
Old 02-17-2009, 01:24 PM   #8 (permalink)
jonmills's Avatar
Thanks. I'll give it a shot.
Old 02-17-2009, 08:48 PM   #9 (permalink)
Owner for 3.8 years
Kermit's Avatar
OHHH! and don't do it in the dark. You may want to be in a well lit area while you're doing all this so you can see what goes where. Ask me how I know. (mark me down as a member of smart bloodied knuckle air filter changing club)
Old 02-18-2009, 06:12 PM   #10 (permalink)
GHammerly's Avatar
Just changed my oil today, while at it I decided to take a look at the air filter and what a PITA it is. I disconected the hose from the airbox cover and was going to remove it entirely but it's attached to a bracket with an imposible to get to torx bolt.
I had to deflect the intake hose at the belows more than I'm comfortable with to get it out of the way, if I do this every time the plastic bellows will brake.
I like the airbox design, even the intake duct looks large and smooth, just don't like the hose and resonator between the airbox and throttle.
Door panel removal Westfield 11 smart General Discussion 5 02-20-2009 11:11 PM
Stalks End Cap Removal graphix1998 Interior & Exterior 6 11-22-2008 04:52 AM
clock removal? stlsmartguy smart Modifications 8 07-26-2008 04:43 PM
Grill removal smart i am Interior & Exterior 19 06-17-2008 10:57 PM
Florida lovebug removal? flpat smart General Discussion 10 05-11-2008 07:19 PM
