Old 04-20-2009, 02:44 PM   #1 (permalink)
alarm keeps going off
What am I doing right/Wrong, My alarm keeps going off, I check all my doors and set the alarm, in less then 30 sec. the alarm starts sounding again.
othermom02 is offline   Reply With Quote
Old 04-20-2009, 02:58 PM   #2 (permalink)
Mod./Adm.
Drive: w/s/r '08 passion
Do you have a pet in the car? Or under it?
How long did you have your car?
Has it happened before?
Did you talk to your Dealer?
If it's still doing it, push the button to disable the motion detector (in the button bank under the radio) before locking your car and that'll give you some peace until you can have your car checked.
Hope it helps!
Old 04-20-2009, 04:12 PM   #3 (permalink)
NeWave's Avatar
Drive: 05 Impala, 09 Passion
Most likely the microwave motion sensor. I had the same problem. Just deactivate the motion sensor like JPaul said.
Old 04-20-2009, 04:34 PM   #4 (permalink)
My car is in the shop right now because of the problem with the alarm going off. It is the electro microwave element. Your dealer will need to order it if its not in stock. It takes an hour to replace. Good luck
Shore is offline   Reply With Quote
Old 04-20-2009, 05:31 PM   #5 (permalink)
With luck, that's it and it's a simple fix. I had it too when the car was new. Once the motion sensor was replaced, all has been well (about a year now.) Hope you have the same good luck!
Old 04-20-2009, 07:15 PM   #6 (permalink)
Drive: rx7
In my case was the towing sensor.
Alarm goes off reloaded rubyg Smart Car Operation and Maintenance 10 01-11-2009 08:24 PM
New car fun! (Setting off the alarm) JD10367 Smart Car General Discussion 7 12-01-2008 12:44 PM
Cabrio & alarm JPaul smart fortwo (451 - US vehicle) 2 10-02-2008 06:47 AM
adding an alarm smartfloridadad Smart Car Modifications 3 08-27-2008 06:10 AM
4am TLC time?? (alarm) aktlsz Smart Car Operation and Maintenance 3 06-30-2008 06:38 PM
