Alarm malfunctioning! - Smart Car of America Forums : Smart Car Forum
Old 09-29-2009, 10:41 AM   #1 (permalink)
Spumonti's Avatar
Long time no post, but here I am with some annoying problem that the dealer can't seem to pinpoint. Intermittently, when I lock the car, after about 30 seconds, the alarm starts going off. So basically, I have to leave my smart unlocked all the time... Its very frustrating!
Anybody have any experience with this kind of issue?
Spumonti is offline   Reply With Quote
Old 09-29-2009, 10:52 AM   #2 (permalink)
You never write, you never call, and now you want our help?
Seriously, no idea although there were a few spurious alarm activations at the Dragon meet this weekend. There must be an alarm module they can replace, or one of the sensors is going bad perhaps?
Old 09-29-2009, 11:09 AM   #3 (permalink)
I have had the same problem on many different occasions. Some of the times it would stop others times I had to leave it unlocked. Most of the time unlucky for me happens in the middle of the night. We need to get this fixed, considered going to the dealership but its not something I can make happen when they are looking at it.
Jeremy_Gunnels is offline   Reply With Quote
Old 09-29-2009, 11:12 AM   #4 (permalink)
Admin/Mod.
smart is very discreet about where the ground sensor on the underside is located. May be loose?
Old 09-29-2009, 04:31 PM   #5 (permalink)
I've started having the issue too. I found it was the microwave module. Apparently when the temperature inside shifts past the dew point of the car's interior a slight film can develop and trigger the sensor. There's about 3 weeks in the spring and fall that I have to turn off the sensor via the console to stop the car from going off repeatedly. :P
Old 09-29-2009, 04:45 PM   #6 (permalink)
I had that problem when my '08 was new. It was cured by replacing the interior microwave sensor and has not recurred.
Old 09-29-2009, 05:34 PM   #7 (permalink)
Spumonti, this is not as good as a wiring diagram but may help you locate various alarm system parts.
Hope it helps.
Old 09-29-2009, 05:41 PM   #8 (permalink)
This is probably better for location:
Old 09-29-2009, 05:51 PM   #9 (permalink)
in my 2008
Was the towing sensor and had no code, there is no code for the alarm sensors.
Old 09-29-2009, 08:43 PM   #10 (permalink)
Spumonti's Avatar
Thanks guys
alarm keeps going off othermom02 smart Operation and Maintenance 7 03-22-2010 09:41 AM
Ugh, not again... (alarm) NeWave smart Operation and Maintenance 11 03-04-2010 03:20 AM
Alarm falcon269 New Members Area 4 09-10-2009 01:56 PM
New car fun! (Setting off the alarm) JD10367 smart General Discussion 7 12-01-2008 12:44 PM
After Market Alarm kitttie OC Smarties 1 06-23-2008 11:12 PM
