Alternator going out - Smart Car of America Forums : Smart Car Forum
Old 08-31-2010, 06:48 AM   #1 (permalink)
bumblebee's Avatar
My smart is currently in the shop with the alternator gone bad. Car is at 47,000 miles. Has anyone else replaced their alternator?
bumblebee is offline   Reply With Quote
Old 08-31-2010, 07:14 AM   #2 (permalink)
banned
Other than your battery dying what are the symptoms?
Old 08-31-2010, 08:00 AM   #3 (permalink)
bumblebee's Avatar
Sluggish start. Sometimes it takes 5 - 6 tries before it start. The battery light came and stayed on this morning.
Old 08-31-2010, 09:09 AM   #4 (permalink)
a2jack's Avatar
BB. Just a couple of questions here... Did you get the free battery upgrade? Do you have it in a Smart Center shop?
Expect the Shop to come up with one or more of "The Big Three $$$" parts replacements, as well as, maybe, fix the problem.
First step here should be to charge the battery. Next take a voltage output reading on the Alt (head lights on).
If alt is around 13-14 volts the problem could be as simple as dirty battery terminals.
Good luck. A2Jack
Old 08-31-2010, 10:17 AM   #5 (permalink)
donnyonee's Avatar
and thats a drop the craddle to fix job, bummer. i think.
if you do it yourself, maybe drop the 1 side a little and wiggle it out thru the top?
does anyone know if the motor loom can be unplugged and plugged back in with the batterey dissconnected and no problems result?
Old 08-31-2010, 05:28 PM   #6 (permalink)
GiantKiller's Avatar
Yah you can unplug the engine comp. and trans with battery disconected. I wouldn't do it without disconecting the bat first.
Old 08-31-2010, 08:25 PM   #7 (permalink)
bumblebee's Avatar
Good luck. A2Jack
Yes, i got the free battery upgrade. The battery is fine but not charging. I did bought the extended warranty and it's covered. Smart Center of Dallas has been pretty upfront with me and have not try to find other problems to fix other than the ones I have. If all goes well I'll pick it up tomorrow.
Old 09-06-2010, 08:12 PM   #8 (permalink)
a2jack's Avatar
BB. What was the outcome on your start problem? A2Jack
Old 09-06-2010, 08:51 PM   #9 (permalink)
donnyonee's Avatar
geez, you could have said it was on warranty. i havent slept for days.
Alternator Output? knipdlo smart General Discussion 8 09-04-2011 01:46 PM
help (450 alternator wiring) cbm-class New Members Area 3 05-19-2010 10:27 PM
How to get a 450 alternator tested? atikovi smart General Discussion 3 11-14-2009 07:52 PM
Alternator Upgrade DkxSpikee smart General Discussion 8 02-17-2009 05:31 PM
Looking for info on the Alternator iamgnat smart Modifications 19 03-28-2008 04:12 AM
