Another "Is this normal?" question - Smart Car of America Forums : Smart Car Forum
Old 12-03-2008, 10:58 AM   #1 (permalink)
Padawan's Avatar
Today, I noticed a slight but obvious whirring / whoosing noise coming from the floor right near the passenger seat bottom. My first guess would be the fuel pump, but I want to check with others to see if it's "normal". Any input?
Old 12-03-2008, 11:07 AM   #2 (permalink)
Could you be hearing the HVAC fan dying? How much airflow do you have with the fan set on high? The fan/motor is in the center stack rather than the floor but the sound source can be tricky. If the fan on high is less than a hurricane, that would be my first guess without seeing the car.
Old 12-03-2008, 11:33 AM   #3 (permalink)
Admin/Mod.
Do you hear that "noise" only for a short period of time just after starting the engine, or continuously? Can you be more specific? Thanks.
Old 12-03-2008, 11:45 AM   #4 (permalink)
Hey, as long as it's between (or among) consenting adults, who are we to say?
Old 12-03-2008, 12:49 PM   #5 (permalink)
Padawan's Avatar
it's definitely not the fan, since it works fine on all speeds and the noise occurs with the fan off. It is a constant noise whenever the car is running, and definitely coming from near the battery. After work I'll see if it starts with the key set to "ON", which might confirm the fuel pump idea.
Old 12-03-2008, 01:59 PM   #6 (permalink)
I have the exact same noise and it is constant. I found I can hear it from outside the car as well if I put my head down next to the passenger side undercarriage. It is definitely loudest from underneath the passenger seat.
I took my car into the dealership to look into a few issues and described this to them as well. I used the same terminology "whirring/wooshing." They couldn't seem to hear it though they did find that I needed a new driver side speaker, so I know they really did check out my issues.
windscythe is offline   Reply With Quote
Old 12-03-2008, 05:11 PM   #7 (permalink)
Originally Posted by Padawan View Post
... My first guess would be the fuel pump, but I want to check with others to see if it's "normal". Any input?
If it was the fuel pump you would hear it distinctly cycling about three times per second. To verify that sound/frequency, just remove the gas cap and listen down the fuel filler pipe with the engine running.
Old 12-03-2008, 11:34 PM   #8 (permalink)
grwhitaker's Avatar
Before or after?
So, do I light the match before or after I have removed the gas cap to see what I am doing? I'm a former blonde, so I confuse easily...
grwhitaker is offline   Reply With Quote
Old 12-04-2008, 07:01 AM   #9 (permalink)
Cute, but don't suggest it, some may follow
It may qualify you for the Darwin awards, but it's not funny in real life. I saw a gas tanker truck driver who did just that to look down the hatch on the top of the tank. (He was burned over 90% of his body, he didn't make it.)
Old 12-08-2008, 10:43 AM   #10 (permalink)
Sounds like it could be your fuel pump, they all make a little noise but I have replaced 2 here at the shop as they made a pretty loud noise. Seemed to get worse when the tank was full.
There is a bit of foam padding in the floor, but as the pump is right under you it can still be a bit loud.
smartSEATTLE is offline   Reply With Quote
"Passion" badge removal question stevenvillatoro Interior & Exterior 19 08-17-2008 05:07 PM
After receiving your "vin" # question please... Nicholas smart Reservations 16 06-27-2008 10:15 AM
A question for all you "hypermilers" out there bull8042 smart General Discussion 15 06-10-2008 07:09 PM
Engine "break-in" question Tom Burns smart fortwo (451 - US vehicle) 6 12-30-2007 02:20 PM
