Anybody having problems with tranny engaging? - Smart Car of America Forums : Smart Car Forum
Trailer
Old 10-09-2008, 05:49 AM   #1 (permalink)
pdboilermaker's Avatar
On occasion, our car does not seem to want to go into gear. It has failed to go into reverse when put into reverse and has failed to go into drive when put into drive.
Anyone else?
pdboilermaker is offline   Reply With Quote
Old 10-09-2008, 06:09 AM   #2 (permalink)
Admin/Mod.
Just an idea: do you feel like trying to "re-teach" your car's computer (ECU) its gears pattern?
See:
http://www.smartcarofamerica.com/for...834-post5.html
Hope it helps. Keep us posted.
Thank you.
Old 10-09-2008, 12:18 PM   #3 (permalink)
Anyone else?
This can also occur if the vehicle has not come to a complete stop. The vehicle is hesitant to engage a gear if it thinks the vehicle is still in motion. Being computer controled the trans can only go off the info it is being given.
smartSEATTLE is offline   Reply With Quote
Old 10-09-2008, 01:47 PM   #4 (permalink)
headless's Avatar
The obvious thing is you are not putting your foot on the footbrake while shifting into gear, this is the main cause of trouble, try it and get back to me on this post
Old 10-11-2008, 04:45 PM   #5 (permalink)
The parking brake will disable clutch engagement at idle. Make sure it is completely off and the light is out.
Old 10-11-2008, 04:55 PM   #6 (permalink)
Cruising n Coasting's Avatar
Huh!!!!!
Old 10-11-2008, 10:28 PM   #7 (permalink)
I had 2 major chassis shakin' clunks today in reverse...reminded me of putting Jeep in 4-wheel drive & gears grinding...
WorldFamousCPA is offline   Reply With Quote
Old 10-13-2008, 11:17 AM   #8 (permalink)
I would try the "learn" sequence so you have the best possible alignment of the sensors to the control unit just for grins.
I carry my Cabrio often in the garage of a motorcoach. I like the car being backed in so the little bit of engine weight is more toward the coach rear axle line. This means backing up a ramp whilst having it centered in the garage and stopping at just the right spot and hopefully not driving through the wall and stuff like that.
This seems to work just fine as long as I use the hand brake to control the car and keeping the revs up. If I use the foot brake then goofy stuff happens with the reverse creep or sumthin and it makes me nuts. With hand brake control all is well and loading the Cabrio up the ramp is a no sweat deal, even with wet tires and such.
Old 10-13-2008, 12:57 PM   #9 (permalink)
HGB
HGB's Avatar
Visit dealer asap before they have to tow it there. I just had mine towed because of a faulty gear shift lever. In all probability it will be replaced. It's a quick cure if that's what's the problem.
Old 10-13-2008, 01:00 PM   #10 (permalink)
OK HGB was yours doing the same? difficulty finding the gear?
How can you live with the tranny? dw103 smart Operation and Maintenance 44 12-02-2008 05:38 PM
First Oil & Tranny Service at 1300 miles fielddominance smart General Discussion 27 07-06-2008 11:01 PM
Tranny Shifter Update... sort of.... Steven79 smart General Discussion 9 04-07-2008 07:43 PM
tranny creep wolfmanoicu812 smart General Discussion 6 02-29-2008 09:06 AM
? for those who drove new smart semi-auto tranny mr_Cash smart General Discussion 80 02-01-2008 08:56 PM
