Anyone do a DIY oil change yet? - Page 2 - Smart Car of America Forums : Smart Car Forum
Old 04-23-2008, 06:56 PM   #11 (permalink)
38 years of oil changes, this is flat out the easiest ever. A poorly trained monkey could do it. Enjoy........
Old 04-24-2008, 07:29 AM   #12 (permalink)
NY Smartie's Avatar
well, thank goodness I am a well-trained monkey then. ;)
Old 04-24-2008, 09:25 AM   #13 (permalink)
The synthetic oil that comes in the smart is more than capable of going 10k miles between changes. When Mobil 1 first came on the market they tested it at 25,000 miles between changes, their test engines speced out as new engines at 100k........but I would agree with making an initial change earlier to clear out any machining debris (I know there isn't supposed to be any) left in the engine.
Ralph Finneren is offline   Reply With Quote
Old 04-24-2008, 10:02 AM   #14 (permalink)
NY Smartie's Avatar
you make a good point there. something about making the first one soon after the break-in period makes sense to me.
Old 04-24-2008, 10:07 AM   #15 (permalink)
dcrooks's Avatar
Yeah, I am approaching the 5K mark and I already bought the Mobil 1 at Costco. I just need the oil filter and plug. I gather it is best to get those at the smart center?
dcrooks is offline   Reply With Quote
Old 04-24-2008, 10:09 AM   #16 (permalink)
NY Smartie's Avatar
what weight range is recommended? 5w/30? just wondering.
Old 04-24-2008, 10:24 AM   #17 (permalink)
Senior Smartie
jonnysan's Avatar
The recommended oil viscosity is...
0-40W Mobil 1. In hotter climes I would use 5-40W although the 0 and the 5 are what to expect at the low end of the temperature ranges where you live.
Old 04-24-2008, 10:25 AM   #18 (permalink)
dcrooks's Avatar
Yes, 5w/30...
Old 04-24-2008, 11:06 AM   #19 (permalink)
NY Smartie's Avatar
well, I have hot summers and cold winters, so, I better get my sh*t toegther!
Old 04-24-2008, 11:46 AM   #20 (permalink)
Your LI (JKF APT.) annual mean temperature over the past 62 years is +54F, with a record high of +104F and a record low of –02F.
You can check out the smart oil viscosity chart (left out of the US Operators Instructions) on Evilution to see what viscosities cover your temperature range. 0W-xx isn’t good unless you REALLY need it. http://www.evilution.co.uk/index.php...&men=servicing
$100 oil change?? tiny smart smart Operation and Maintenance 73 06-01-2009 04:26 AM
first oil change thestevens5 smart General Discussion 14 08-28-2008 12:26 AM
I got my first oil change Connelly New Jersey Chapter 3 08-20-2008 05:05 AM
oil change SmartDigger smart Operation and Maintenance 9 04-11-2008 10:48 PM
Oil Change anthonype3 smart Operation and Maintenance 42 03-28-2008 10:09 AM
