Automated manual transmission control unit - Smart Car of America Forums : Smart Car Forum
Old 11-21-2008, 11:19 AM   #1 (permalink)
So, what's really controlling the transmission?
Location
The automated manual transmission control unit is located in the passenger compartment under the driver seat.
General
The transmission control converts the driver's shift requests into corresponding control signals to the clutch and the 5-speed automated manual transmission. This is done by relaying the shift signal about the shift request at the electronic selector lever module control unit over a direct line to the automated manual transmission control unit. The automated manual transmission control unit checks the plausibility of the shift request in relation to the vehicle speed, the load (accelerator pedal position) and the engine speed. If the plausibility check is passed, the automated manual transmission control unit sends the signal to initiate the selected shift operation to the two actuator motors for the two selector drums and to the clutch motor to open or close the clutch.
Task
The automated manual transmission control unit controls the following functions depending on the input information:
• Engaging first gear at vehicle standstill
• Gear change
• Compulsory upshift just before maximum engine speed is reached
• Compulsory downshift when engine idle speed is approached
• Downshift for kickdown
• Disengaging the gear after 1 s when a door is opened without the service brake or accelerator pedal being actuated
• Crawl function
• Clutch operation
• Monitoring of clutch load
The automated manual transmission control unit directly reads the signals from the following components:
• Transmission rpm sensor (L2)
• Transmission motor 1 (M17/3)
• Transmission motor 2 (M17/4)
• Clutch motor (M18)
• Electronic selector lever module control unit (N15/5)
• Park pawl switch (S16/2)
Old 11-21-2008, 01:22 PM   #2 (permalink)
Ok, John, that' a bit more informative than any other similar posts here, is there a LOT more where that came from? Inquiring minds need to know........
Old 11-21-2008, 02:31 PM   #3 (permalink)
In the technical spec manual
Old 11-21-2008, 07:09 PM   #4 (permalink)
This stuff can't be right. The salesman didn't tell me any of this stuff...lol
Old 11-21-2008, 07:16 PM   #5 (permalink)
Being able to paddle shift while in "D" is nice. I actually use that on our Mini.
Old 11-21-2008, 09:06 PM   #6 (permalink)
smart happens here!
SmartCard's Avatar
under the driver seat huh?
That explains the irregular shifting behaviour when I pass gas!
Old 11-21-2008, 09:57 PM   #7 (permalink)
...and new meaning to the "three bars of death"
Old 11-21-2008, 10:00 PM   #8 (permalink)
Not on the 08s, but apparently has been added to the 09s.
Old 11-22-2008, 06:48 AM   #9 (permalink)
Supporting Tuner
Evilution's Avatar
This was all controlled by the ECU before in the 450 but the addition of an extra gearchange motor and their insistence on using a dumber ECU meant the job had to be farmed out to an extra unit.
__________________
Old 11-22-2008, 12:01 PM   #10 (permalink)
Location
I don't quite get it....there is the passenger's side, and the driver's side. How do you get to the "passenger compartment under the driver seat"? Under the driver's seat belongs to the driver's side.
Is this one of those "the left side of your right hand" thing?
Transmission shifting questions (auto vs. manual) JD10367 smart General Discussion 32 11-29-2009 02:20 PM
Automated car wash cirofeola smart General Discussion 24 10-15-2008 09:33 PM
automated manual transmission. MaybeWereCrazyBaby smart General Discussion 3 09-28-2008 07:23 AM
electric-auto manual or manual with clutch pedal, your favorite? mr_Cash smart General Discussion 47 02-19-2008 10:05 AM
Manual Transmission Walrus smart General Discussion 25 11-13-2007 10:53 AM
