HOME FORUMS GALLERY CLUBS
Old 06-04-2008, 11:00 PM   #11 (permalink)
curtis's Avatar
Drive: 08 Smart & 03ToyotaMatrix
I'd just tell the truth like Jthomas said, he plugged in an audio device. That is the absolute truth so help me god.
Old 06-04-2008, 11:11 PM   #12 (permalink)
Smart Car Geek's Avatar
Originally Posted by curtis View Post
its an Aux input, you should be able to plug in a radio with and earphone jack
No you shouldn't, it would over power it and burn it out. Aux level is much lower, similar to a preamp level. For one the impedance would be different. However without seeing what was used and how it was used who knows what really happened. I would think that the owners manual should list some sort of specs. The bottom line is that the aux input was not happy with what it saw ;)
Old 06-05-2008, 01:03 AM   #13 (permalink)
Smart Enuf's Avatar
The manual (p. 144) says:
"You can connect mobile audio devices such as an MP3 player via smart MP3 interface* (AUX-socket*) using a commercially available 3.5 mm socket plug."
That's all it says. There's no prohibition on "old" radios, whatever that means.
There are only two elements in that sentence that you need to meet (aside from using the AUX-socket, which you plainly did): (1) your radio has to be a "mobile audio device" (i.e., portable rather than a home stereo), and (2) you used a "commercially available 3.5 mm socket plug" (as opposed to some plug/wire you kludged together). The "such as an MP3 player" qualifier does not limit your choices to only MP3 players, so you're radio is still okay so far.
As long as you met both of the above requirements, I don't see why you need to lie or be silent about it. Tell them the truth; you'll feel better, and perhaps smart will learn something about this that they didn't know before. For example, maybe there's an previously unknown design flaw with the radio.
Which brings up a separate but possibly related point. If I recall, someone pointed out in an earlier thread that smart warns against using cellphones in the smart. Most readers brushed this off as a typical CYA disclaimer. However, your experience and the comment on unfiltered RF modulators suggests to me that maybe the smart radio is sensitive to other radio transmissions. I still don't see a problem with you mentioning your old radio, since smart's warning covered cellphones and said nothing about using old portable radios in the car.
Old 06-05-2008, 01:38 AM   #14 (permalink)
I don't see him as outright lying. Remember this is HIS money that you are so easily spending here. If he doesn't tell the dealership exactly what they want to hear, then they will not cover this under warranty. What happened - happened, it's spilled milk. His main concern now should be to get it repaired under warranty and to learn from the experience ;)
The manual clearly states "such as an MP3 player via smart MP3 interface" (iPod, zune, etc.) so that would all depend on if his 'old radio' can play MP3's or not. From the way he described it I doubt it can. He can always call a different dealer and have then specifically explain what is meant by "mobile audio device" and take it from there.
Old 06-05-2008, 03:48 AM   #15 (permalink)
Can bus
If you guys knew how heavily can-bussed this car is you would freak out. Almost everything except the radio is tied into one of several CAN (Control Area Network) data buses.
I concur with the assessment that plugging in an old radio (which was ill-advised) caused RF havoc. And no, I can't explain why that would happen, but it did. Don't try that again, just plug in your iPod next time. Although something tells me anyone who had an old transistor radio lying around isn't quite at the iPod evolutionary stage yet.
rollingtones is offline   Reply With Quote
Old 06-05-2008, 04:37 AM   #16 (permalink)
Hates cinder blocks
mdfortwoguy's Avatar
Drive: '02 Saturn VUE, '08 smart
You are aware that an iPod, Zune, Sansa, or the other myriad of MP3 players utilize the (amplified) headphone out jack for connection to this, correct?
Old 06-05-2008, 04:46 AM   #17 (permalink)
Drive: 08 Smart Pure & 04 MS MX-5
The Aux input is a line-in, so while it can handle some higher volume levels, there is a limit at which it would be getting too much power and potentially damage something. It may be this old radio could go SUPER loud and it was at its loudest setting when it got plugged in?
Old 06-05-2008, 05:03 AM   #18 (permalink)
Modérateur
Drive: w/s/r 08 passion
When I plug in my iPod/iPhone, I have to set it to its highest volume to get enough gain. Granted, I've limited the device's output to shield my ears when using a headset.
Note that the device "remembers" what was the output setting the last time I plugged something to it. Therefor, when I use the headset after I've used the device in the car, I have to remember to lower the level, otherwise it is way too hot.
Old 06-05-2008, 05:24 AM   #19 (permalink)
Fredvon4's Avatar
I suspect a simple coincedence of this...
The aux in line goes to only ONE place: the inputs on the back of the radio...period
The out put of the OLD radio source earphone / speaker jack is high level AF ( Audio Frequency) and should NOT cause this concedental weirdness IMO
IF this is NOT coincedence I suspect this:
The external source (old radio) had volume way up
The radio 9/10 high impedance 100~600ohm input section does not have a blocking diode or filter
The source signal some how over loaded the radio circuitry and fed back out on the CAN buss line B to the SAM unit and latched the warning light circuits...
NO matter how this happend I think the SAM is confused or damaged and will need replaced or all codes cleared and re-set by a dealer computer
Old 06-05-2008, 05:44 AM   #20 (permalink)
UNTODDLY's Avatar
Ok that ruins my idea for plugging a guitar through it...
UNTODDLY is offline   Reply With Quote
aux input, radio, warning lights
Forum Jump
Possible 2nd aux input? jwight Audio & Video 4 06-04-2008 08:24 AM
Two major complaints about my SMART jetdok5 Smart Car General Discussion 33 04-25-2008 05:11 PM
Engine failures, major problems any? bwimpee Smart Car Operation and Maintenance 4 03-21-2008 12:37 PM
Major snow storm wis and Il. rwj53 Smart Car General Discussion 4 02-06-2008 08:11 PM
Newbee Looking for Input classicsmarts New Members Area 5 12-03-2007 10:15 AM
