Brake disc replacement - Smart Car of America Forums : Smart Car Forum
Old 05-29-2009, 05:31 AM   #1 (permalink)
Hi peeps, I've heard that the front brake discs and pads are difficult to change on the Smart for two from a DIY perspective. Can anyone advice on if its a DIY task and if there are any bits i need to watch out for?
Thanks
Mark
marksmart is offline   Reply With Quote
Old 05-29-2009, 06:27 AM   #2 (permalink)
SmartWillie's Avatar
Check out Evilution Picture based instructions.
SmartWillie is offline   Reply With Quote
Old 05-29-2009, 07:53 AM   #3 (permalink)
randyzimmer's Avatar
451s are a little different than the 450 shown (caliper bracket held by 18mm standard bolt head rather than E18) but not enough to worry about.
The job is as easy as any - not like an old Renault where you had to press the hub off the spindle to get the disk off.
Old 02-04-2012, 04:50 PM   #4 (permalink)
Evilution pictures are for the front not the rear brakes, but thanks anyway.
Joeking is offline   Reply With Quote
Old 02-04-2012, 06:38 PM   #5 (permalink)
The following You Tube video is for a Roadster but other than the location of the Master Cylinder Reservoir it should be the same.
Ken Boothe is offline   Reply With Quote
The Following User Says Thank You to Ken Boothe For This Useful Post:
Pee-wee German (02-04-2012)
Old 02-04-2012, 07:57 PM   #6 (permalink)
padi176715's Avatar
Whoever told you that was mistaken. I had not changed brakes in over 20 years, and was able to the pads and rotors in under 25 minutes. Not even a little challenge. I put on ebc red pads and ebc slotted rotors and this has reduced the dust on the wheels by an amazing amount. Let the fun continue
padi176715 is online now   Reply With Quote
Old 02-04-2012, 08:26 PM   #7 (permalink)
Owner for 3.8 years
Kermit's Avatar
I've swapped out both sides before in a parking lot of a store in minutes. VERY easy if you are slightly mechanically inclined. If you are not, they are still bearable if you can follow directions.
Truly one of the easiest cars I've ever done and I have done a lot.
Old 02-04-2012, 09:07 PM   #8 (permalink)
I thought it was very easy. I don't have much to compare it to, though.
deepblueQ is offline   Reply With Quote
Old 02-05-2012, 06:54 AM   #9 (permalink)
WhiteNBlack08's Avatar
Incredibly easy. Can be done in 20 minutes easy....
Old 02-05-2012, 08:30 AM   #10 (permalink)
WOW!! a few time warps there, your smart has gone 20 years on one set of brakes??? (Just kidding with ya) I have changed a lot of brakes out over the years, and there were no surprises with my smart. Pretty straightforward.
Smart Passion 2008 Smart Passion Convertible Automatic A/C 6-Disc CD Smart Cars For Sale Archive/obsolete (?) threads 0 05-17-2009 07:00 AM
Brake wear - brake life HotCookCpl smart General Discussion 24 05-04-2009 06:16 PM
6 disc changer radio 10 coreyeh Archive/obsolete (?) threads 2 03-10-2009 05:17 PM
FOR SALE: Radio 10 6 Disc CD Changer [SOLD] doogster Archive/obsolete (?) threads 2 12-17-2008 05:51 AM
Glass replacement in SC bull8042 Carolinas Chapter 3 06-11-2008 08:00 AM
