Brake rotor ? - Smart Car of America Forums : Smart Car Forum
Old 11-17-2009, 04:10 PM   #1 (permalink)
SmartDigger's Avatar
Brake rotor ?
I have one of the front rotors getting a groove in it. it is about 1/2 inch in from the outer edge. What could be causing this and can it be stopped? Like a rock or something.
Old 11-17-2009, 04:55 PM   #2 (permalink)
JOIN SCOA.YOU'LL BE GLAD
..yes Digger..a rock can cause that but the noise level when using the brakes will be a clue of something is not right...have you had your brake pads checked?...I know you did the wheels not long ago...it would have been the perfect time...and with only 3 lug nuts it should take no time to go in there and take a look...
..a stock pad/pug could also create an uneven wear pattern...
jetfuel...hitting the brakes..
Old 11-17-2009, 06:56 PM   #3 (permalink)
Godfather's Avatar
Hmmm...... got two rotors and pads under the bench...... I'm ready.
Old 11-17-2009, 08:33 PM   #4 (permalink)
There is no noise from it at all, the braking is smooth. Could be a hard chunk in the pad. I just never saw a "V" type groove with the rest perfectly smooth. I have seen ridges before though. I'll just have to keep an eye on it. If it gets bad I might have to upgrade to ceramic pads and new rotors later on.
Brake wear - brake life HotCookCpl smart General Discussion 24 05-04-2009 06:16 PM
EBC brake pads WhiteNBlack08 smart Operation and Maintenance 14 04-08-2009 12:56 PM
Tow Brake? Bumbee smart Towing 8 12-23-2008 09:49 AM
EBC Brake up grades SmartTech smart Modifications 7 07-02-2008 04:03 PM
Brake Dust SnakeFarm smart General Discussion 21 04-28-2008 03:36 PM
