Is the cabrio roof supposed to bead water? - Page 3 - Smart Car of America Forums : Smart Car Forum
Old 07-03-2009, 07:46 AM   #21 (permalink)
Padawan's Avatar
Originally Posted by NCC1701 View Post
I had planned to treat mine Spring and Fall. Now, I'm baffled as to why my roof is different from almost everyone else's, and am not sure what I should do. Several of y'all have said it's nothing to worry about if it isn't leaking. But, I don't like that it doesn't bead anway. Just doesn't seem healthy.
I would try several different products. To the best of my knowledge, there is nothing applied to the fabric from the factory, since it's synthetic and not canvas. It certainly doesn't sound as if you received some sort of "defective" top, so just experiment until you find a protectant that provides the results you're after. Raggtopp is good and well-known (sort of like the Mobil 1 of top care), but there are definitely others and each has slightly different properties and results.
Old 07-03-2009, 08:13 AM   #22 (permalink)
Periclaws's Avatar
Old 07-03-2009, 08:18 AM   #23 (permalink)
Mom liked you better
The Rigger's Avatar
Originally Posted by headless View Post
Ahhhh, the sun, we had that once here too, back in the heatwave of 1984, it was visible behind a layer of light cloud for 15 minutes, pheeeewww what a scorcher that was
So John Lucas does the sunlight in England too?
Old 07-03-2009, 08:28 AM   #24 (permalink)
The Rigger's Avatar
NCC: For what it's worth, my top doesn't bead water either.
Old 07-03-2009, 02:39 PM   #25 (permalink)
Been smart for 3.59 years
NCC1701's Avatar
Originally Posted by John_H View Post
Does it not bead after a constant rain or does it not bead when dry, then splashed?
I haven't tried 'splashing' it. Like a light sprinkle from a garden hose? I don't know. But, so far as a normal rain shower which would wet the ground, or a normal rinse when washing the car ... no beading, just wet surface.
When you say the fabric is synthetic ... does that mean canvas with some kind of polymer coating, or the fabric itself is some kind of synthetic fiber? Maybe the roof needs the treatments which are designed for vinyl roofs??
Someone suggested a visit to a marine store for a suggestion for waterproofing treatment.
Can anyone explain the fact that some here report their tops have repelled water from day one without treatment, and others don't ... before or after treatment? Doesn't that seem peculiar to anyone else? Someone may say it doesn't matter. Some don't have any curiosity.
Old 07-03-2009, 03:22 PM   #26 (permalink)
BELJO's Avatar
Cabrio care
Got my 2009 Brabus Cabrio in March. I have never owned a convertible before so I did a little reseach as to its care. The smart cabrio as you know has a fabric top as opposed to vinyl. RAGG TOPP convertible top Cleaner and Fabric Protectant did a great job. All I do now is hose off the top and dry with a dark colored towel so as to not leave lint. It always looks great and beads water. Just be sure to follow the directions for thsy warn it can be harmful to the paint.
My top never beaded water before treatment.
BELJO is offline   Reply With Quote
Old 07-03-2009, 03:41 PM   #27 (permalink)
NCC1701's Avatar
Please read post #1 in this thread. If RaggTopp had done the trick for me, I wouldn't have started this thread. Thanks anyway, glad it worked for you.
Old 07-03-2009, 03:58 PM   #28 (permalink)
Padawan's Avatar
The outer layer is "polycyclic fabric", which is a synthetic weave. Canvas tops are normally some sort of treated cotton blend.
That's a good suggestion. Protectants for marine fabric tops would be a good choice, and are often less expensive than the boutique automotive top care products.
My guess is that it's a combination of factors such as how much water is hitting the top (a bit of rain, or a soaking, or something in between), as well as how long the car was exposed to the elements before delivery, the way the car is washed, if it's garaged, etc.
Today, for example, I washed All Ball and the flat portion of the top beaded up, but the sides and back surrounding the window were exposed to more water for more time, which saturated them to the point where it was not beading at all.
Old 07-03-2009, 04:37 PM   #29 (permalink)
headless's Avatar
Who is John Lucas?
Old 07-03-2009, 06:49 PM   #30 (permalink)
The Rigger's Avatar
Who is John Lucas?
You're kidding, right? I'm sorry; I thought you were British.
John "The Prince of Darkness" Lucas, of Lucas Electrics? Doesn't ring a bell?
Is there any way to make the Cabrio roof close.... doogster smart General Discussion 13 10-01-2010 03:08 AM
Squeek/Rattle in cabrio roof rails spikey01 smart Operation and Maintenance 15 07-31-2010 07:16 AM
Cabrio roof...which is it? pwbapro smart General Discussion 16 08-12-2008 11:27 AM
Does your cabrio roof button light up? wrumbarger smart General Discussion 6 06-18-2008 09:07 AM
Stuck Cabrio Roof wrumbarger smart Operation and Maintenance 2 04-30-2008 08:29 AM
