Cabrio tailgate lock failure - Smart Car of America Forums : Smart Car Forum
Old 03-28-2008, 11:36 AM   #1 (permalink)
The electric lock on my cabrio tailgate stopped working, hence I'm unable to open the gate. It was working that morning, and a few hours later it stopped. With the gate locked, there is no way to remove the inside panel to gain access to the mechanism. I wonder if a fuse has blown. Unfortunately, the owners manual does not indicate which fuse protects that circuit. Any help or advice would be most appreciated. I'd like to avoid a 150 mile roundtrip journey back to the dealer.
Hal2 is offline   Reply With Quote
Old 03-28-2008, 11:42 AM   #2 (permalink)
Do your horn and other locks work? Fuse 31 goes to the horn and central locking. Didn't see one for the tailgate at:
http://www.evilution.co.uk/index.php...d=353&men=info
Disclaimer: this may only be for UK 451s, I'm not sure
Old 03-28-2008, 01:42 PM   #3 (permalink)
Senior Smartie
jonnysan's Avatar
Hal...I suppose you have tried ...
Double clicking the unlock button on the dash?
Old 03-28-2008, 09:47 PM   #4 (permalink)
GiantKiller's Avatar
My tailgate lock was not working. Eric at smart center in milwaukee. Said it is a known problem with the cabrio. An adjustment of a leaver inside. That the micro switch was actually on. and not allowed to switch off. He adjusted it and I haven't had a problem since
Old 03-29-2008, 11:02 AM   #5 (permalink)
If you disconnect the battery would that release the solenoid? If so, you could get the tailgate open and attempt the adjustment at home with a little telephone help from your smart center. Let us know what finally happens with the "known problem."
Old 03-29-2008, 12:14 PM   #6 (permalink)
24-42's Avatar
Or pull the fuse for the tailgate.
Old 03-29-2008, 11:08 PM   #7 (permalink)
I'm having the same problem, hopefully I can get it looked at soon. Just picked up the car a week ago, but live 120 miles from the dealer.
rkracketeer is offline   Reply With Quote
Old 03-30-2008, 05:41 AM   #8 (permalink)
Had an intermittent problem last night for the first time. My smart goes to the dealer tomorrow.
Also have an issue with the automatic mode on the manual transmission. It has an irritating habit of not shifting up from first gear. Even if I let off the gas slightly for a few seconds to give it a chance to shift.
dirlink is offline   Reply With Quote
Old 03-30-2008, 05:48 AM   #9 (permalink)
MichaelJ's Avatar
Typically, no. Solenoids only get current when they are active, otherwise there'd be a constant drain on the system.
MichaelJ is offline   Reply With Quote
Old 03-30-2008, 06:22 AM   #10 (permalink)
Update on the repair
After going through the various troubleshooting efforts, the microswitch was determined to be bad. The technician replaced the switch, and the tailgate was operational.
failure to start- 3 bars smart1 smart Operation and Maintenance 2 03-10-2008 07:53 AM
Tailgate smarty42 smart Operation and Maintenance 8 02-23-2008 11:56 AM
Tailgate? Wile E. Coyote smart General Discussion 20 10-30-2007 03:15 PM
Why the lock down? lhoboy smart News & Rumors 7 09-26-2007 08:07 PM
