Can you push start a smart? - Smart Car of America Forums : Smart Car Forum
Old 02-28-2008, 10:55 AM   #1 (permalink)
Re: the dead battery post, can you bump start a smart by pushing it or rolling down a hill?
Old 02-28-2008, 11:40 AM   #2 (permalink)
24-42's Avatar
YES !
Donald LaFavor
Old 02-28-2008, 11:56 AM   #3 (permalink)
Any computer controlled engine that exists through a cat you run a risk of killing the cat with a minor blast caused by raw fuel getting lit off there.
I will pass thanks
Old 02-28-2008, 12:12 PM   #4 (permalink)
I have a question. Or two. Does the ECU know that you are in 'start' mode if the key is left in the run position? In start mode I assume the air/fuel ratio is modified. If the battery is dead forget it. The alternator will not help you, you will have no fuel pump and so on. But I think the actual question is a situation where the battery is too low to spin the starter. Since there is no clutch pedal, the normal way to decouple the starting motor on a push start, do you move the lever to neutral? How fast is that process? I suspect that is also an electric motor to make that change. As for raw fuel, this does not appear much different than the cylinder discharge in a situation where the car will not start because of a wet ignition. This is speculation on my part and I hope to learn more.
Kysmart is offline   Reply With Quote
Old 02-28-2008, 12:28 PM   #5 (permalink)
try search this has all been beaten to death
Old 02-28-2008, 12:43 PM   #6 (permalink)
24-42's Avatar
ROLL STARTING
1. Foot on brake
2. Ign. on
3. Shift to Neutral
4. shift to + and hold, 'N' changes to '1'
5. Foot off brake put accelerator to floor
6. Begin rolling
7 car starts
Donald LaFavor
You don't need a really steep hill nor high speed
Works for me.
Old 02-28-2008, 03:49 PM   #7 (permalink)
I live on a hill and will try this tomorrow. It's a good tool to have in your kit if the starter won't work for whatever reason.
Old 02-28-2008, 05:29 PM   #8 (permalink)
Supporting Tuner
Evilution's Avatar
Old 02-28-2008, 05:53 PM   #9 (permalink)
Admin/Mod.
Being neither technophile nor technophobe, just technologically inclined, I'm tempted to say "read the fine manual". But I do understand that some manuals are difficult to read, let alone understand. Is this the case here? (I'm still waiting for delivery...)
Old 02-28-2008, 07:00 PM   #10 (permalink)
a2jack's Avatar
Manual OK.
JPaul: Manual is better than most. But any car manual is, at least, worth one or two reads just to know where to find things.
A2Jack
Remote start rwj53 smart Operation and Maintenance 18 12-19-2010 09:48 AM
Noise when you first start the car eqwalker smart fortwo (451 - US vehicle) 10 02-21-2008 05:02 PM
Can a 451 be Push-Started? LorbeerTLC smart Operation and Maintenance 7 01-29-2008 11:10 PM
jump start??? maxtraxduffy smart Operation and Maintenance 19 01-27-2008 10:26 AM
When did they start employing robots at Smart? KeyserSoze smart Reservations 6 01-12-2008 09:31 PM
