Can you skip shift? - Page 3 - Smart Car of America Forums : Smart Car Forum
Old 02-14-2008, 12:17 PM   #21 (permalink)
The owners manual dissuades using engine breaking during the break in period, break pads are cheaper than engine rebuilds BTW. it does very smooth downshifts.
Old 02-14-2008, 12:18 PM   #22 (permalink)
Originally Posted by paul c View Post
If I'm not mistaken, that third pull will put you in second.
you are correct
Old 02-14-2008, 12:39 PM   #23 (permalink)
24-42's Avatar
Originally Posted by LorbeerTLC View Post
When I come off the freeway in my del Sol, I rev the engine to match the RPM's speed in 4th, shifting from 5th to 4th, it's very smooth. I continue this sequence down to about 3rd gear. This saves wear & tear on the brakes.
Can you do this in the 451 or does it kill engine speed when it disengages the clutch?
-Tom L.
The clutch will remain engaged down to less than 10mph. You could downshift to 1st gear if you wish to. Matching rpm to the car speed of the selected gear is not only smooth, but easier on the clutch.
That is part of the learning curve, the challange if you will, of you and your car becoming 'One', 'A team'.
As I have stated before, it is a std. sequencial transmission.
Downshifting is 'SOP' for us (old) sports car (MG TC,TD,TY) drivers. ( I downshift my wife's automatic).
The smart does this very well.
Learn the rpm for each gear at any speed within that gear's range (tach is very helpful).
Donald LaFavor
Old 02-14-2008, 01:39 PM   #24 (permalink)
Odd
That is very odd. With most new cars the recommendation is to vary speed and use engine braking to seat the rings properly.
I've never bought the 'engine braking is bad' BS. And neither have the four vehicles I've owned that have gone 200K miles or more.....without rebuilds.
cosmart is offline   Reply With Quote
Old 02-14-2008, 06:45 PM   #25 (permalink)
Senior Smartie
jonnysan's Avatar
I think they want to dissuade using engine breaking because...
It would be very easy to over-rev the engine if you downshifted alittle too far given a particular road speed. Engine breaking during break-in is good for properly breaking in the compression rings as it creates negative pressure in the combustion chamber and draws lubrication up into the rings to keep them lubricated as the break in. The oil rings also benefit for the same reason.
John
Old 02-14-2008, 09:09 PM   #26 (permalink)
24-42's Avatar
John
This becomes a mute point if you follow what I said in my post above.
To be able to downshift with confidence, do the following;
1. In manual mode, begin in 1st gear, accelerate to it's max comfortable speed (mph)
IF YOU DON'T UNDERSTAND THE PRECEEDING STATEMENT, STOP READING AND DON'T ATTEMPT TO DOWNSHIFT.
For those who are still with me, make a note of the max mph for 1st gear.
2. Shift to 2nd and follow the same procedure.
3. Shift to 3rd and same same.
4. Shift to 4th and same same.
When downshifting, do not downshift to the next gear if your car speed is higher than the max you determined when you made your note.
If you have a tachometer you can do the same as above using rpm instead of mph.
Donald LaFavor
Old 02-17-2008, 06:53 AM   #27 (permalink)
Only three pages to say no
Old 02-17-2008, 07:49 AM   #28 (permalink)
Robbie51's Avatar
Sorry I wasnt clear. In my starting this thread I was really talking about skip shifting up not down, but thanks for all the info.
Robbie51 is offline   Reply With Quote
Old 02-17-2008, 07:54 AM   #29 (permalink)
No need to be sorry, just thought it was funny that it took so much discussion to say no or no you can not or something more to the point.
enjoy
Old 02-17-2008, 07:57 AM   #30 (permalink)
Robbie51's Avatar
enjoy
Still a neat disscussion.
3rd shift? bentoutofshape smart General Discussion 19 02-11-2008 11:10 AM
Automatic stick shift???? bob/cathy smart Operation and Maintenance 5 01-20-2008 12:10 PM
Gear Shift Delay MicroNut smart General Discussion 12 11-11-2007 08:37 PM
