Car Beeps Incessantly When In Gear? - Smart Car of America Forums : Smart Car Forum
Old 11-17-2009, 10:25 AM   #1 (permalink)
powerbookguy's Avatar
i am having an intermittent problem with my car. it starts up and seems to run fine but when i put it in gear (D or R) there is an incessant beeping. the beeping stops when in N or P. seat belt is in use and there are no idiot lights on. the door locks do not engage automatically. the blinkers do not work properly (they light up but i do not hear the normal relay sound). otherwise car seems to drive normally.
this has happened three times now. the first time i corrected it (or so i thought) by disconnecting the battery. it happened again when i first started the car this am. an hour later, starting the car for a second time the beeping was gone. 15 minutes later starting the car for a third time the beeping has come back.
could this be a bad ecu?
powerbookguy is offline   Reply With Quote
Old 11-17-2009, 10:31 AM   #2 (permalink)
Check that the doors are completely closed - it sometimes takes some umph as the car is very tight. They can be ajar, but look like they are closed. A common culprit is the passenger's seatbelt buckle caught in the jamb. That will also cause the cabin light to stay on.
Old 11-17-2009, 10:39 AM   #3 (permalink)
thanks a lot, will check that asap.
Old 11-17-2009, 01:05 PM   #4 (permalink)
it looks like it was the door ajar!
thanks.
Old 11-17-2009, 01:28 PM   #5 (permalink)
thanks.
Well, is it a door or a jar
Old 11-17-2009, 01:30 PM   #6 (permalink)
Chris Wurgler's Avatar
Old smart comes thru again
Chris Wurgler is offline   Reply With Quote
Old 11-17-2009, 01:45 PM   #7 (permalink)
yeah!
Old 11-17-2009, 07:31 PM   #8 (permalink)
The Super Shoe
mdfortwoguy's Avatar
You bring up a good point. This car does not have a traditional flasher - the lights are controlled by the SAM, and the "click" you hear is computer generated. It prioritizes sound output - a door ajar in gear is more important than a turn signal, so it sounds the more important alarm.
Old 11-20-2009, 03:23 PM   #9 (permalink)
SubSlr88's Avatar
That is amazing~! I continue to learn stuff about this little car...
Old 11-20-2009, 10:14 PM   #10 (permalink)
DoraAnderson's Avatar
Is the seatbelt fastened all the way, and if you have something on the passenger seat, you need to fasten that seatbelt too if it's heavy enough.
DoraAnderson is offline   Reply With Quote
Rev Limit by Gear in MPH? powerbookguy smart Operation and Maintenance 29 12-21-2009 01:41 AM
5 Beeps? (upon turning ignition off) kulak New Members Area 12 05-13-2009 08:28 PM
Locking without the three beeps JPaul smart Operation and Maintenance 22 02-22-2009 01:40 PM
Car stalls in First gear, please help BlueDan Original (450) smart fortwo 9 12-06-2008 10:15 PM
Where's the Beeps? KingNine smart Operation and Maintenance 2 04-13-2008 05:03 PM
