change brake fluid (2005 smart diesel) ? - Smart Car of America Forums : Smart Car Forum
Old 08-19-2009, 06:03 AM   #1 (permalink)
Does anyone know how to change the bake fluid ona 2005 smart deisel?
Thanks
chillyryan is offline   Reply With Quote
Old 08-19-2009, 08:49 AM   #2 (permalink)
Old 08-19-2009, 08:52 AM   #3 (permalink)
Padawan's Avatar
Wait, so do you want him to check out Evilution - Smart Car Encyclopaedia?
Old 08-19-2009, 08:59 AM   #4 (permalink)
Always an option.
Old 08-19-2009, 10:26 AM   #5 (permalink)
I personally don't like any of the methods on those pages, unless I missed something, and prefer to do it this way (the way that the Corvette service manual advices):
Open the brake fluid reservoir cup and remove as much of the fluid as possible while still keeping the bottom inlet area under fluid. Top off the container with new clean fluid.
Hook up a drain tube to the farthest (rear passenger) bleeder and open it. The force of gravity will cause the fluid to run out. Keep an eye on the reservoir, keep it topped up. Once clear new fluid runs cleanly from the bleeder, close it.
Repeat for all 3 additional brake fittings, moving close to the reservoir each time.
This method is considered the least harsh on gaskets and seals. Older Vettes apparently have a problem with some seal if you use a power bleeder or pump the brakes during the job. This can take a few hours to do, but it's not very intense and as long as you are keeping an eye on the reservoir, it's not bad at all. I think I did my Cherokee in about 2-2.5 hours, so the smart should be faster.
sandalscout is offline   Reply With Quote
Is neccesary to replace the brake fluid at 20k? rubyg smart Operation and Maintenance 103 05-19-2010 04:00 PM
Best transmission (oil) for 451? torqueaholic smart Operation and Maintenance 62 10-25-2009 02:39 PM
Transmission Fluid for Smart Marco smart Operation and Maintenance 13 06-03-2009 03:10 PM
Brake wear - brake life HotCookCpl smart General Discussion 24 05-04-2009 06:16 PM
Anyone purchased smart transmission fluid? Padawan smart Operation and Maintenance 26 04-04-2009 08:31 PM
