Changing the air filter (major pita) - Page 2 - Smart Car of America Forums : Smart Car Forum
Old 03-07-2009, 03:09 PM   #11 (permalink)
jonmills's Avatar
I was having major problems. The temperature went to 70 today and it took 10 minutes. Ambient temp makes a difference.
jonmills is offline   Reply With Quote
Old 03-09-2009, 12:15 PM   #12 (permalink)
SylenThunder's Avatar
It took me about 3 minutes to install my K&N filter. But then, I have done the "50 cent" mod already and removed the dampners. Hose is a LOT easier to work with now.
Old 03-10-2009, 06:21 PM   #13 (permalink)
yellow smart's Avatar
Originally Posted by Dan1776 View Post
Check out my reply under "air filter changing". My fix really makes this a snap thing to do. .
Dan1776
Post a photo or describe your procedure here. I had to dig for your other post.
Yellow-Smart
yellow smart is offline   Reply With Quote
Old 03-13-2009, 07:24 PM   #14 (permalink)
This shows the inner tube and hose clamps used to seal the cut/broken pipe coming from the air filter box. Future filter changes are then easy after removing the additional clamps shown. Bending or twisting of the parts is then not required when removing the air filter housing top for filter replacement/cleaning.
Dan1776 is offline   Reply With Quote
Old 03-29-2009, 04:38 PM   #15 (permalink)
Senior Smartie
jonnysan's Avatar
Great idea...here's a coupling...
You can buy at Home Depot that does the same thing if you don't have a bicycle inner tube....it's called a "FernCo Coupling" and it can be found in the Plumbing isle at either Home Depot or Lowe's.
