Changing the spark plugs - Smart Car Forums
post #1 of 21 (permalink) Old 03-15-2012, 07:33 AM Thread Starter
Is there anyone in New England that has done their own? Looking for someone willing to help me.
Pasde2 is offline
post #2 of 21 (permalink) Old 03-15-2012, 10:48 AM
95K miles of smiles
Quoted: 79 Post(s)
It's not really hard; if this "fluffy", old, crippled geezer can do it ........
read this over: Plug Change
chief..................
chieftmc is offline
post #3 of 21 (permalink) Old 03-15-2012, 10:52 AM
tigerwong58's Avatar
Quoted: 2 Post(s)
It's easy to do, just invest in the correct length extensions for your spark plug socket. Lube the new spark plug with spark plug lube or anti sieze and do not tighten too tight, once it's snug maybe another 1/8 turn.
tigerwong58 is offline
The Following User Says Thank You to tigerwong58 For This Useful Post:
Smart Bob (03-15-2012)
post #4 of 21 (permalink) Old 03-15-2012, 04:33 PM
Quoted: 136 Post(s)
If you choose to replace the spark plugs yourself, you might keep this in mind. Instead of putting the replacement spark plug into a socket to start the threads in the spark plug hole, use a piece of rubber hose, like fuel line, and push that over the porcelain upper part of the spark plug. One does not have to push it all the way on because you only want to use it to start the plug. That way, if the plug is not started correctly the plug will catch and the hose will slip on the plug. If that happens, back it out and try again. You should be able to screw the plug in with the hose until the sealing washer contacts the cylinder head. Then remove the hose and tighten with your socket. This also works when removing the plugs if you do not have the proper spark plug socket with a rubber insert to hold the plug. Loosen the plug, then remove the socket and push the hose on it and back it out.
Rustedwrench is offline
The Following 4 Users Say Thank You to Rustedwrench For This Useful Post:
ca smartone (03-15-2012), CharlieK (03-15-2012), HGB (03-15-2012), Smart Bob (03-17-2012)
post #5 of 21 (permalink) Old 03-15-2012, 05:58 PM
Yes....I've done it....easy job!!! Happy to help.
djp55 is offline
The Following User Says Thank You to djp55 For This Useful Post:
Pasde2 (03-17-2012)
post #6 of 21 (permalink) Old 03-15-2012, 06:25 PM
CT Chapter President
smartcar111's Avatar
Quoted: 6 Post(s)
I did it too!
smartcar111 is offline
The Following User Says Thank You to smartcar111 For This Useful Post:
Pasde2 (03-17-2012)
post #7 of 21 (permalink) Old 03-17-2012, 05:55 AM Thread Starter
Yay
I'm looking for moral support I will do the work, just like the idea of an experienced person around.
Pasde2 is offline
post #8 of 21 (permalink) Old 03-17-2012, 10:11 AM
Quoted: 2 Post(s)
just changed mine yesterday.
Only thing I would add to all of the posts I've read....make sure and remove the airpump hose near the right coil - it makes getting the socket on much easier.
And....use a little dielectric grease in the coil boot before pushing on installed plug. That stuff is magic!!
m3456y is offline
The Following User Says Thank You to m3456y For This Useful Post:
post #9 of 21 (permalink) Old 03-21-2012, 02:43 PM
Great meeting you today Pasde2. Hopefully the drive home was smooth and the new plugs helped a bit. Next time you'll be a pro at it doing it yourself.
djp55 is offline
Kermit (03-21-2012)
post #10 of 21 (permalink) Old 03-21-2012, 03:41 PM
Quoted: 6 Post(s)
And I found the most comfortable way to work on it was from the front passenger area with the seat push up all the way and the back folded forward. Then I just laid in the open area and I was able to get a good view of the work I was doing.
Hope that helps too!
tablist180 is offline
The Following 2 Users Say Thank You to tablist180 For This Useful Post:
kesmith (08-22-2012), wahi (07-25-2012)
Human Verification
331
Pulstar spark plugs chieftmc smart Operation and Maintenance 19 08-28-2014 10:22 PM
Spark Plugs? GeekGirl smart General Discussion 40 04-11-2014 09:11 AM
451 spark plugs jwight smart Operation and Maintenance 24 01-02-2014 05:31 PM
Changing the spark plugs - Evilution guide. Evilution smart Operation and Maintenance 7 12-06-2010 03:42 PM
