» Site Navigation |
Helpful Links
smart USA Newsletters
Other Links
» Recent Threads |
03-30-2008, 05:52 PM
#31 (permalink)
My check engine light came on at 750 miles. Actually, to be technically correct, it is a MIL light (Malfunction Indicator Light). Anyway, I got an appointment with my dealer in Devon, Pa. I live 100 miles away, and it took me a week and 450 miles later to get down there. Needless to say, the morning I left for the dealership, the MIL went out. It did have a code pertaining to the evaporative/purge system indicating a major leak (similar to a missing or loose gas cap). Does anyone see a pattern here? Obviously the cars are experiencing a problem with these solenoids/sensors/ switches. It would seem that the solenoids are sticking open at times, triggering the light. I'm sure that as more cars are having the problem, a TSB (technical service bulletin) or recall will be issued.
04-02-2008, 03:16 PM
#33 (permalink)
Twistwrench - got ya beat - I am 140 miles away from the Devon Dealership. Funny, our check engine light went on at .... 750 miles too! Weird. Anyway, we did NOT want to make the trip, so we took previous advice on this post and purchased an OBDII/CAN compatible code scanner - hooked it up, it read as one of the fuel vapor leak codes, reset it, and haven't had a problem since (although its only been a week). We are now compulsively turning the gas cap 642 times after filling up ;)
Anyway, highly suggest this approach to anyone to see if check engine light is really a technical problem or temporary gas cap issue - saved us 300 miles on a highway.
Djinn
04-02-2008, 03:25 PM
#34 (permalink)
Drive: ’08 W451 premium coupé
One wonders how many of these "Check Engine Light" episodes can be due to overfilling the gas tank.
04-12-2008, 07:22 AM
#36 (permalink)
Check engine light
Recieved my car on 5 April yesterday 11 April at 450 miles the check engine light went on the car drove fine and I continued to do errands I already had a 10:00 am appt with the MB service dept for installation of some options, so I was not worried. This was the diagnosis: Client states check engine light is on current fault P0410/secondary air system is faulty Performed quick test/function tested air injection system/AI pump and switch over valve are operating/found loose wire at air pump/corrected wire problem/ran air readiness tests and function tests/cleared fault memory. No cost to me. Never did the car run rough or start up with any difficult. Had only one fillup with attention paid to putting the gas cap on snug. Still having a great time, I love this car!
04-13-2008, 11:47 AM
#37 (permalink)
engine light is on
My wife just got home and said the engine light came on after putting fuel into the car. Gas cap is tight, she may have over fill it. How can you reset the light? Thanks
04-13-2008, 11:49 AM
#38 (permalink)
Some say that will go out by itself in time. Dunno.
04-13-2008, 12:10 PM
#40 (permalink)
Still worth getting it checked. In my case if you read my post from yesterday it was a loose wire, and I was very deliberate about the gas cap tightness and not overfilling.
| Thread Tools |
| Display Modes |
Linear Mode
LinkBack to this Thread: http://www.smartcarofamerica.com/forums/f25/check-engine-light-3886/
| Posted By |
For |
Type |
Date |
| All Cars, All the Time |
This thread |
Refback |
09-02-2008 05:21 PM |
