HOME FORUMS GALLERY CLUBS
Old 04-21-2008, 12:51 AM   #51 (permalink)
Drive: fortwo Passion Coupe
Originally Posted by Djinn View Post
one other code scanner question. Apparently, the current standard is OBD II, however some 2008 cars have started using the latest standard called "CAN". See this quote from a review on Amazon ...
"NOTE: Starting in 2008, a new standard called "CAN" will become mandatory for all vehicles, and some auto manufacturers are already producing CAN-compliant vehicles. OBD II code readers may or may not work with CAN vehicles ** check the product detail page to check if the scanner works with OBD II, CAN, or both"
Of course, scanners that can read both are more expensive. Anyone know which standard the smart passion uses - OBDII or CAN?
Djinn
CAN has been around for a long time. I worked for BMW Motorsport for a couple of years about '99-00. BMW road cars had CAN-bus back then; way ahead of the curve. Some of the fun facts I learned from BMW "master techs" included:
One third of the time, the MIL is triggered by the gas cap not being tightened until it clicks, or the tank is filled drop-by-drop until full to the cap. The Siemens ecu is very sensitive to this. It is doubtful that the smart/Mitzu uses Siemens hardware, but it's a common problem. Sometimes my Mini runs perfectly until a fill-up, and then it bucks and hesitates fir a few miles, sometimes with the light flashing. Then it goes away. If you remove and reseal the cap, the MIL might not go off for a few days.
Another 30-40% of the time, these guys claimed that the light triggered because of a bad sensor. The code would point to where, and it would be replaced. Reset the control unit, and the problem is gone. There are dozens of sensors today, and they're in a harsh environment, so they often fail. But sometimes they are fine and set off the light.
The rest of the time, the sensors show that there is a problem and a non-sensor part needs to be replaced.
The most important thing is to not panic. If the car starts to run badly, don't drive it, call roadside assistance. If it runs fine, it might have been a momentary disruption of voltage, and the light comes on. The thing to do is find the code, and turn the MIL off. If it happens again, then something needs to be done. It could be a vacuum line pinching or leaking, an O2 sensor, or a hundred other things.
If you throw a code, drop by an Autozone store and they will be happy to plug an appropriate code reader into your car. There really isn't any reason for the average owner to invest in one. Get the code, and have them reset the light. They don't charge a thing for doing it. If the light comes on again, then you should make an appointment with the dealer. But on a modern new car, it isn't uncommon that it doesn't come back.
What would help the community the most is to get the list of codes specific to the fortwo, and if people see them, post them on the forum so we can see what is happening. Some of them may be quirky things, and others may be things that will be cured by a running change in production, and our cars will get retrofits. Others may be nothing at all.
Old 04-21-2008, 01:31 PM   #52 (permalink)
SD_smart_Guy
Gene_SD's Avatar
Drive: 08 smart passion
First update on Check Engine Light(Code P0410): Dropped car off at dealer this morning @ 7am they said they will keep it for a couple of days to test it out. This is the second visit to the dealer in less than a week, I hope they see and fix the problem. I just want to be on the road with my smart having fun and saving gas.
Update after Pickup from dealer: Code P0410, verified check engine light on, performed short test found code P0410 secondary air injection performed actuation as SDS monitor 02 sensor reading failed. Test performed vaccuum system test air injection. Failed, checked all vaccuum hoses performed switchover valve actuation found malfunction in valve. Replaced and Repaired, rechecked system function with SDS secondary air injection test o2 sensor change <2 volts within spec pass test. Cleared all codes performed extended road test for customer satisfaction on cold startup no further faults or events stored made control unit log on hard copy.
So it fits into what I have found on this and other forums. "Valve Problems for smart".....
Gene_SD is offline   Reply With Quote
Old 04-23-2008, 04:13 PM   #53 (permalink)
Drive: Lexus
Emissions Error
Got the same error one week after I got my car - 4010 - emmissions. Taking my car to the dealer monday 45 min. away in Laguna Niguel - They better fix the problem and not just clear the code - I can do that from here!
renah is offline   Reply With Quote
Old 04-25-2008, 08:00 AM   #54 (permalink)
vanslam's Avatar
Drive: Corvette, HD, Ercoupe
Well after 3300 miles I just joined the Check Engine Light club. While driving to work I noticed that the orange engine light was on. I have to call the dealer and drop the car off. I know it is not the as cap because the tank only has 2 bars left and I checked it already anyway. I'll keep you all up to date on the results from the dealer.
vanslam is offline   Reply With Quote
Old 04-25-2008, 07:49 PM   #55 (permalink)
vanslam's Avatar
Well here is the update, I had the Code P0410 issue. The value was replaced and system checked. Everything is back to normal. Best part was that the service was free and I got a free car wash as well.
Old 04-25-2008, 08:17 PM   #56 (permalink)
MinneSmarta
slime's Avatar
Drive: 2 SmartCars
Check lite
Had one and less than 10 min later, dealer fixed. NOT a gas cap problem, just Great service here in the GREAT state of Minnesota.
slime is offline   Reply With Quote
Old 05-01-2008, 07:39 AM   #57 (permalink)
Drive: Lexus
Valve replaced
Well the valve was the problem on my smart too. Laguna Niguel gave me a nice loaner car, and had my smart ready the next day. They are a class act over there. Also - got my first wash there - it's like starting over!
Old 05-01-2008, 10:21 AM   #58 (permalink)
On my second day of driving I went over a rough patch of road and the "Check Engine Light" came on. I immediately noticed a lack of power and a rough idle. I drove another mile to work and got out the manual called the dealer and left a message. I went back out to the car and looked for any visible damage and there was none. Started the car, no light, drove a few miles and it was operating fine. Dealer called back and recommended I come back in and have the car hooked up to the computer. I am still on the original tank of fuel so I don't think the fuel cap is an issue. Do you think the jolting of the car somehow confused the whole car?
PMazOD is offline   Reply With Quote
Old 05-01-2008, 01:04 PM   #59 (permalink)
diegosilang's Avatar
Drive: 2007 Benz
An Epidemic?
Count me in too on this dreaded check engine light problem. I picked up my car last Friday afternoon 4/25/08, currently have 250 miles on it and now have that same P0410 secondary air emissions problem (scangauge 2). Spoke to the dealer at Walters Riverside for service and was told that the smart technician would not be in till 5/10/08. They would not even give me a loaner. I was outraged and told them the car is barely a week old with 250 miles on it and I would not even get a loaner! They said they would get back to me later and find out. It runs great though and I am loving every minute of it.
diegosilang is offline   Reply With Quote
Old 05-01-2008, 01:45 PM   #60 (permalink)
vanslam's Avatar
You van always call Smart USA and they will find a dealer to fix your problem and flatbed it to be fixed if needed. They offered the option to me but I wanted to drive.
Forum Jump
LinkBack to this Thread: http://www.smartcarofamerica.com/forums/f25/check-engine-light-3886/
All Cars, All the Time This thread Refback 09-02-2008 05:21 PM
SRS Indicator Light SmartCab08 Smart Car General Discussion 35 12-20-2008 06:30 PM
Light at the end of the tunnel? skyzdlimit59 Smart Car General Discussion 2 02-15-2008 04:27 PM
Third brake light pulsar jwight Interior & Exterior 3 12-23-2007 10:06 AM
Check My Math SnakeFarm Smart Car General Discussion 3 12-20-2007 11:37 PM
