Check Engine Warning light with Scangauge code P0301 - Smart Car of America Forums : Smart Car Forum
Old 07-29-2008, 11:53 AM   #1 (permalink)
We suddenly developed a Check Engine Warning light. The car ran very rough for a few seconds, I pulled over and the light came on. I sat for a while and then restarted the car and drove home without any problem - all has been fine since. Our Scangauge showed error code P0301 -#1 cylinder not firing correctly. The light stayed on for a couple of days and then went off. Our scangauge still reports the error on a scan.
I've searched the forums and have a good idea of possible causes but has anyone heard of a engine warning light going out by itself?
This happened over the weekend so we just called into the Smart dealership but there wasn't any "knowledgeable" smart service person there who could answer our questions. We will keep trying, but in the meantime . . . Any feedback would be appreciated. We live 2 hrs from the closest dealer.
jagzoo is offline   Reply With Quote
Old 07-29-2008, 11:57 AM   #2 (permalink)
engine light will often go out after a number of warm-up cycles have transpired without a detected issue.
Old 07-29-2008, 12:02 PM   #3 (permalink)
Great! Thanks.
Do you know why the Scangauge still reports the problem? I've tried to clear it in the scangauge but it just goes blank and doesn't reset.
Old 07-29-2008, 12:05 PM   #4 (permalink)
MPrice2984's Avatar
P0301 in a car this new would probably indicate a bad connection between the spark plug and coil pack. You might have had a little condensation in one of your plug wire boots that just needed to burn off.
MPrice2984 is online now   Reply With Quote
Old 07-29-2008, 12:05 PM   #5 (permalink)
the code is stored in the car's puter even after the CEL goes out. at least, that's how my other vehicles have operated.
not sure why you can't clear it with the scangauge - although, i thought i read somewhere that not all codes can be cleared by the SG. maybe im imagining that part tho.
Old 07-29-2008, 12:09 PM   #6 (permalink)
Check out the thread here:http://www.smartcarofamerica.com/for...problem-11172/
there have been some reported problems.
Old 07-29-2008, 04:44 PM   #7 (permalink)
I had the same problem the first week of ownership. It happened about 3 or 4 times and each time I would pull over, check the Scanguage for a code, shut the car off and restart. When I re-started the car, everything would be normal, light out and no codes.
I only got a code once, P0303 - misfire on cyl. #3. But I cleared it with no problem with the Scanguage. And it has not occurred in just over a month of ownership and a little over 700 miles.
I wish I could be more help, but since the car stopped doing it, I didn't want to show up at the dealer, an hour away, for them to say they don't see any problems.
tjmodz is offline   Reply With Quote
Old 08-03-2008, 02:25 PM   #8 (permalink)
Hi,
Well, still no repeat of the "check engine" light but now the scangauge reports code P0302 instead of the earlier P0301! We are trying to get an answer from our dealer about this whole issue but so far no luck.
Check Engine Light dcrooks smart Operation and Maintenance 218 12-13-2011 02:53 PM
Check Engine light: Code U0002 getsmartusa smart General Discussion 31 12-05-2011 10:11 PM
TPS Warning Light graphix1998 smart Wheels & Tires 7 05-18-2010 09:16 PM
Check Engine Light and CPU Reset Gene_SD smart Operation and Maintenance 1 04-18-2008 07:33 PM
Check Engine Light, 400-500 miles thefitness smart General Discussion 4 03-23-2008 09:33 PM
