Now that I've got it, sooner or later I'm gonna have to wash it. Does anyone know if it's a no-no to use ammonia-based window cleaners on the polycarbonate roof panel, as would be true with most plastics? The ammonia imparts a haze over time. Until I find out, I'll just be using car soap and water. Thanks!
The Polycarbonate Roof has a Silicone Hard Coating on it. So it is no Problem to use ammonia Type cleaners. It is even more scratchresistent than the rest of the car. So it does not make the same trouple as pure PC-Glacing on Boats, Airplanes ...
I would rather take care obout the Roof spoiler and the Black Covers on the C-Column. These Parts are just molded in Color uncoated parts. They scratch more easely but can also be polished easily afterwards.
Use a polyurethane polish like Finish 2001 and you can use it on practically the whole car, headlights, roof and powder-coated areas included. The nice thing is that it lasts a long time and helps keep bugs and other items from sticking. It takes more effort to buff off than the label would have you believe, but given how long it lasts, that's a trade off worth living with.
After thirty years of riding Honda Goldwing Motorcycles and cleaning so many polycarbonate and lexan windshields, you DO need to know one VERY important thing about cleaning the Panorama roof.
NEVER clean the roof with WINDEX or any cleaner that has amonia. I learned the hard way! WINDEX causes small "starburst cracks" in plastic that will ruin the roof. I suggest using "Honda spray polish" which is designed for plastics and also paint with no possible harm to the finish..Also other cleaners that are also good are "Plexus" and "210 plastic cleaner" but the Honda cleaner is far superior to the others in my opinion.
None of these cleaners have any abrasives in them. Good luck with your roof. Waymon 132
After thirty years of riding Honda Goldwing motorcycles and cleaning so many polycarbonate and lexan windshields, you do need to know one important thing about cleaning your Panorama roof. NEVER clean the roof with WINDEX or any cleaner that has amonia. I and many of my riding friends learned the hard way! WINDEX causes small "Starburst Cracks" in plastics that will ruin the roof. I suggest using Honda spray polish which is designed for cleaning plastic and paint with no harm to the finish. Also other products such as "Plexus" and "210 Plastic Cleaner" are good but I personally think the Honda Polish works best. None of these cleaners have any abrasives in them. Good luck keeping your "smart" looking the best it can. Waymon 132
Makrolon Cleaning Instructions
The Following techniques for cleaning Makrolon polycarbonate sheet are based on standard
industry practice. To ensure acceptability of the results, always test a sample of the material
with the cleaner and technique to be used.
Guidelines:
Do rinse the sheet with warm water prior to cleaning process.
Don't use abrasives or high alkaline cleaners.
Don't leave cleaners on sheet for long periods, wash immediately.
Don't apply cleaners in direct sunlight or at elevated temperatures.
Don't use scrapers, squeegees or razors.
Don't clean with gasoline.
Do follow the application with a lukewarm water rinse.
Compatible Cleaners and Detergents:
Formula 4091, Joy2, Windex with Ammonia D3, Palmolive4, Naphtha VM&P Grade, Isopropyl Alcohol
To Minimize Fine or Hairline Scratches:
Plastic Polishes applied and removed per manufacturer instructions.
Suggested Polishes:
Mirror Glaze Clear Plastic Polish, Cleaner & Detailer (by Meguiars 800-347-5700 or
Meguiars.com)
Novus Plastics Polish #1, #2 (by Novus Inc. 800-NOVUS60 or noscratch.com)
Plexus Plastic Cleaner and Polish (by BTI Chemical Co. PlexusPlasticCleaner.com)
To Remove Masking Adhesive and Glazing Compound:
Apply Naphtha VM&P grade, Kerosene or Isopropyl Alcohol with clean soft cloth. Wash immediately with soap and lukewarm water and rinse with thoroughly with clean water.
To Remove Graffiti:
Naphtha VM&P grade, Isopropyl Alcohol or Butyl Cellosolve removes paint, marker ink. (Do not use in direct sunlight).
Isopropyl Alcohol, Naphtha VM&P grade or Kerosene will help lift stickers and other adhesive backed labels. Wash immediately with soap and lukewarm water and rinse with thoroughly with clean water.
merged with previous same subject
Reason: merge
I use ArmorAll auto glass cleaner and a micro fiber towel on the entire car, windows and all. It is ammonia free and works really well. So well I use it around the house too.
Any problems using REJEX on the panorama roof? Heard wonderful things about the product and its sold by aircraft websites -applied it earlier today and it needs to cure for 12 hours before exposure to the sun.
