Copper crush washer - Page 3 - Smart Car of America Forums : Smart Car Forum
Old 05-08-2008, 02:27 PM   #21 (permalink)
We might want to beware...Washers are not necessarially equal here. Hardened copper and copper aloy washers may or may not have the propeties necessary to do the job. I know that hard drawn copper pipe is prone to heat stress and cracking where soft drawn copper is not. Before trusting your engine's well being to an insignificant item as a sealing crush washer from Acme Hardware that you paid 75 cents for instead of the dealer crush washer at $3.50 think if it is worth the $2.75 of added cost.
Old 05-08-2008, 02:44 PM   #22 (permalink)
Fredvon4's Avatar
The 0.50c to 0.85c selection at Carcraft, Autozone, and other common car part places are the proper item and designed as sealing washers.... most of the time they carry the item for large truck disk brake Banjo bolts on the high pressure line... they will certainly hold up well in a relatively low pressure drain plug use
The $3.50 or higher at smart part counter are the same item with over 200% profit built in for someone....wink
Nothing wrong with having a "Official smart approved" crush washer... just a waste of money...
IMO
Old 05-08-2008, 02:49 PM   #23 (permalink)
dcrooks's Avatar
IMO
I paid like $2+ for mine at the dealer. With the Mitzu filter it was $15 total.
dcrooks is offline   Reply With Quote
Old 05-08-2008, 06:37 PM   #24 (permalink)
Senior Smartie
jonnysan's Avatar
IF you had to use the Fram....
For better or worse, the Fram TG6607 Tough Guard. xcrew229x and I are the guinea pigs for that filter I guess - in spite of lots of advice not to use Fram filters.
From the oil change thread:
The ToughGuard is the one to get....much higher rated than the plain jane orange with the black rubberized bottom.....
Old 05-08-2008, 07:19 PM   #25 (permalink)
TG6607 is on my smart, And similar Fram filters are on my other four cars, and one truck. Never had a problem. I'm sure the Mitsu/smart filter is good, but I've never subscribed to the whole "dealer part" thing. After all, all oil filters are effectively aftermarket.
Old 05-08-2008, 10:46 PM   #26 (permalink)
This look about right?
nice millstone ya got there, wear that around your neck much
Old 05-09-2008, 08:00 AM   #27 (permalink)
Isn't the rubberized part the top? Just an observation
Old 05-12-2008, 12:13 AM   #28 (permalink)
I gotta think that if someone uses their own washer and it's not the right one for the job that the first thing noticed would be drip spots on the garage floor, long before any engine damage would occur (as more than a quart would need to be lost).
Old 05-12-2008, 08:47 AM   #29 (permalink)
My thought was that with temperature changes there would be issues but I guess if you were on an extended trip, say 300 or so miles, you might notice the oil on the rear window before any damage occurs to the engine. Like fredvon4 stated in his post, you can find suitable inexpensive alternatives if you look.
Old 05-12-2008, 09:47 AM   #30 (permalink)
Again.......2 filters and 2 washers for $30 from my dealer....not huge cash to be able to tell my dealer I have only used M-B/Smart parts......just IMHO.....
copper drain washer dimensions needed scdaf smart Operation and Maintenance 6 04-25-2008 01:54 PM
For Everyone That Has A Crush On The Smart Car LIVNLTL smart General Discussion 8 03-03-2008 08:01 AM
Windshield Washer SBibbo smart Operation and Maintenance 2 02-17-2008 02:04 PM
